Pros and Cons on 1jzgte vs 2jzgte
Old 10-12-11, 09:24 PM
supraclay
supraclay's Avatar
Default Pros and Cons on 1jzgte vs 2jzgte
Im sure this has been asked before but just curious on the pros and cons on going 1jzgte im my sc vs 2jzgte
supraclay is offline
Old 10-12-11, 09:26 PM
supraclay
supraclay's Avatar
oh yea im taking twins off as soon as i get either motor and going single turbo.
Old 10-12-11, 09:27 PM
SChema
SChema's Avatar
Just opened up a can of worms, prepare yourself.
SChema is offline
Old 10-12-11, 09:29 PM
supraclay
supraclay's Avatar
o boy not trying to do that i know the 2jzgte has more potential but just want to know what others think as far as going 1jzgte
Old 10-12-11, 09:42 PM
supraclay
supraclay's Avatar
say i have a part go out on a 1jz can buy parts for 2jz and put it on a 1jz?
Old 10-12-11, 09:47 PM
account2x
account2x's Avatar
biggest difference with twins removed a 2jz has a bigger throttlebody / intake manifold 3" v 2.75", head flows better and more displacement.
if you can afford the 2jz go for it.
account2x is offline
Old 10-12-11, 09:54 PM
supraclay
supraclay's Avatar
thats the problem i dnt think i can but if the parts are interchangeable with the 2jz and i can still make around 400 to 500 hp on stock internals i just might go 1j instead of the king 2j
Old 10-12-11, 10:09 PM
blueboost6
blueboost6's Avatar
400 to 500 horse power on stock internals on a 1j is not that hard as long as your pocket is deep enough.
blueboost6 is offline
Old 10-12-11, 10:12 PM
account2x
account2x's Avatar
It's not the power that's a problem with the 1jz but the power band. all things being equal 1jz will take longer to spool turbo. inverse to make spool faster the turbo would have to be smaller.
Old 10-12-11, 10:34 PM
speed6
speed6's Avatar
ive seen this post on many sites since when i was a noob (1999) ,
it's a difference in engineering, hence the 1JZ AND 2JZ stamped on the side of the block.
Each engine has a set of turbos engineered for the engine, and the ports and valves, heads, intakes, and on and on.
the comparison cannot be readily made, and there is no definitive answer. (deep pockets can buy you hp)
From the box, the 1j will rev higher, given it has a shorter stroke.
the 2j pushes more torque given the longer stroke/ displacement.
now add turbos and injectors and ecu mapping tailor made to extract more power, but not go over the "gentleman's agreement". And what you have is 2 different apples. Compare a washington apple to a granny smith. both are apples, but taste different.
A better comparison would be 1jz or rb25, but still the same can of worms.
think... 1jz turbos on 2jz? no. they wouldnt work the engine would spool them too fast and they would be useless in the upper rpms.2jz turbos on the 1jz? Too laggy for the 2.5l engine.
speed6 is offline
Old 10-13-11, 02:48 AM
BLK13X
Mortgage Slave
BLK13X's Avatar
The 1JZ is a fabulous engine, if you're going for a big single on an earlier engine you may benefit from a set of cams, the VVTi version has gobs of torque in comparison to the earlier series.
BLK13X is offline
Old 10-13-11, 05:12 AM
99SC42
99SC42's Avatar
Op we have couple hundreds threads about this subject please use the search button.
I going to lock this one down.
99SC42 is offline
Supra Dr
149
12-23-14 07:26 PM
//LRD
SC- 1st Gen (1992-2000)
205
09-28-14 01:03 PM
jknox90
02-28-11 04:25 PM
SGordonGs4
16
02-26-10 05:44 PM
happypanda
04-25-06 09:35 PM
Quick Reply: Pros and Cons on 1jzgte vs 2jzgte
