Uplugged power steering connector?
Old 10-16-11, 12:15 PM
ISFFUN
ISFFUN's Avatar
Default Uplugged power steering connector?
Anyone know what this is for ? It's on the back of the rack. I can't find another connector that isn't plugged in.
Old 10-16-11, 12:34 PM
jadu
live.love.laugh.lexus
jadu's Avatar
Im 99% mines is the same way. Ill double check
Old 10-16-11, 02:00 PM
TechGreek
TechGreek's Avatar
That's the speed assisted sensor - i.e. highway and low speed modes.
Old 10-16-11, 04:26 PM
ISFFUN
ISFFUN's Avatar
That's what I thought, but shouldn't it be connected?
Old 10-16-11, 05:57 PM
TechGreek
TechGreek's Avatar
Yes, it should be unless it was having issues and someone left it unplugged.
Old 10-16-11, 07:33 PM
ISFFUN
ISFFUN's Avatar
Could some other people please run out and check theirs? That would be much appreciated.
I'm wondering if that's an SC400 thing only? I have a 300
Old 10-16-11, 08:31 PM
TechGreek
TechGreek's Avatar
I'll quote my self, since you apparently missed my last post.
YES, it is supposed to be plugged into.
Old 10-17-11, 02:57 PM
ISFFUN
ISFFUN's Avatar
Could you please take a phtoto of yours so I can see where the other end might be going?
thx
Old 10-17-11, 04:41 PM
StiCk3
StiCk3's Avatar
that's not the power steering pressure switch as mentioned earlier, that's the one that helps at lower speeds. The connector he mentioned is on the steering rack itself, not the power steering pressure hose as shown in the picture. I've had that same question before and no one knows what it's for and if it has or had a purpose. It hasn't affected power steering on my car at all and haven't worried about it at all.
Old 10-17-11, 05:07 PM
Luxor
Luxor's Avatar
I unplugged mine a few days ago to see if it made a difference in steering. The connector to the PRESSURE SWITCH leads to the main body harness which splits underneath the #1 injector area. One end goes to the main fuse box in the engine bay and there is also a wire that leads to the a/c compressor.
Last edited by Luxor; 10-27-11 at 09:38 PM. Reason: replaced "PPS solenoid" to "pressure switch"
Old 10-17-11, 05:24 PM
TechGreek
TechGreek's Avatar
Whoops - sorry, I did make a mistake on that one.
https://www.clublexus.com/forums/per...ck-pinion.html
Old 10-19-11, 06:24 PM
ISFFUN
ISFFUN's Avatar
I circled the plug in the picture just in case anyone is confused.
Could someone please take a picture on their car?
Old 10-20-11, 07:05 AM
Biggu
Biggu's Avatar
I dont have mine plugged in. If you leave it unplugged the steering is slightly tighter/harder to turn.
Old 10-20-11, 08:18 AM
Luv2xl
Luv2xl's Avatar
there is no plug from the harness to that sensor on the rack which you have circled. I have had 2 SC's to date and none had a plug. Now if you are referring to the 2 wire tiny plug that sits towards the backside of the rack; if you unplug that one that will lead to true upper body workout during parking or low speeds...
I am wondering if you bridged the connection to the pressure control valve, will that provide the tighter steering at all times?
Old 10-21-11, 10:58 AM
Ali SC3
Ali SC3's Avatar
I have a 5 spd and it does not have it.
I always thought the 5 speeds didnt have anything connected to the plug and some automatic models have the plug (this is just an observation, not a fact).
For those posting if they have a connector there or not please state your year/model/transmission so we can get somewhere with this and put this connector mystery to rest.
Quick Reply: Uplugged power steering connector?
