My battery keeps dying
Old 10-24-11, 08:46 AM
spurge
Registered User
spurge's Avatar
Default My battery keeps dying
i have notice this issue for the past 3 weeks, whenever my car sits for like a day it has difficulty starting.
1. i put the key in the ignition, nothing...like the battery is dead
2. 2nd turn, i hear a clicking sound, sounds like those old school kids toy guns we use to play wit.
3. 3rd turn, the car does a slow rev, then it gradually fires up.
now for the rest of the week i do not have this problem because i am driving it daily.
there is corrosion on the negitive terminal but i cleaned it up recently. also i have HID's 6k, i notice if i leave my head lights on without the car being on, it kills my battery, even if i have the door open for too long it will do the same thing kill the battery....looking for the gurus to help me diagnose this problem!!!!
Old 10-24-11, 08:49 AM
cmh
cmh's Avatar
drive it up to a autozone or advanced auto parts and have them hook up the diagnostic machine to it... they will tell u if ur starter, alternator or battery is bad.... thats the first thing i would do seeing as its free.
Old 10-24-11, 08:59 AM
Kohinoor
Kohinoor's Avatar
how old is your battery? and how long do you let the car sit when you arent driving it? days? weeks?
Old 10-24-11, 09:04 AM
junkyard03
junkyard03's Avatar
had that problem when i first bought my sc last year. answer the f'n battery was bought 04 . needless to say it was promptly changed
Old 10-24-11, 09:06 AM
need2boost
need2boost's Avatar
battery....
Old 10-24-11, 09:37 AM
spurge
Registered User
spurge's Avatar
ill check the dates on the battery... any recomendations for a awesome battery thats has great voltage?
Old 10-24-11, 09:42 AM
Kohinoor
Kohinoor's Avatar
die hard gold is the best bang for the buck imo
Old 10-24-11, 09:57 AM
lexfrmtex
lexfrmtex's Avatar
Sounds like its the battery. I had the same issues and it ended up being my battery.
Old 10-24-11, 10:03 AM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
You need to know if it is a parasitic draw before you do anything. Check for that first.
Old 10-24-11, 10:19 AM
spurge
Registered User
spurge's Avatar
parasitic draw??.... O.L.T please explain
Old 10-24-11, 12:47 PM
Teal Sc400
Teal Sc400's Avatar
http://www.youtube.com/watch?v=Ho5oEwSPWCA
Old 10-24-11, 02:20 PM
2jznosht
2jznosht's Avatar
Loosen the negative terminal to where you can pull it off. Start the car and remove the negative cable. If the car stays running the alternator is good. Also when alternators are on thier way out they tend to kill batteries. since the battery sounds like its on its way out, i'd vote new battery then test the alternator.
Old 10-24-11, 02:24 PM
spurge
Registered User
spurge's Avatar
ill test it out later and update you guys
Old 10-24-11, 02:30 PM
alloys999
alloys999's Avatar
its the charging problem it come from dynamo if that dosnt work properly it will not charge battery and battery dies when dynamo does not give charge to the engine so engine will take electric directly from ur battery better change the dynamo and see wht u got
Old 10-25-11, 11:06 AM
spurge
Registered User
spurge's Avatar
where do i get a parasitic test??? where is the dynamo located for me to check this???
Quick Reply: My battery keeps dying
