How to route heater/coolant hoses with a 2JZGTE swap?
Old 11-06-11, 04:33 PM
97-SC300
97-SC300's Avatar
Default How to route heater/coolant hoses with a 2JZGTE swap?
anyone have a clear picture of how to run the heater hoses when doing a GTE swap?
Old 11-07-11, 10:06 AM
97-SC300
97-SC300's Avatar
Anyone?.....
Old 11-08-11, 12:10 PM
Cleanshots
Cleanshots's Avatar
what? it doesnt really matter, route it however you like to make it the cleanest. engine to core from core to valve and from valve back to engine behind the turbos is cleanest routing..
Old 11-08-11, 03:39 PM
97-SC300
97-SC300's Avatar
i needed to know what hoses to use, i bought the supra tt heater hoses and am kind of confused on which ones go where. there are a total of 3 of them. i wanted to know if anyone with a gte swap could take a pic of how their heater hoses are connected so i can have a visual to go off of.
Old 11-08-11, 06:05 PM
soarer13oy
soarer13oy's Avatar
There is an L shaped one that goes from the head to the heater valve. The other ones should go to the tube where the turbos are.
Old 11-09-11, 06:27 AM
Vwpride12
Vwpride12's Avatar
I used the origional SC hoses for the lines that go to the heater valve. The only hose I had replaced with the supra TT hose was the one that goes to the drivers side heater core inlet/outlet to the hard line coming from the back of the turbo. Hope this helps.
Old 11-09-11, 07:00 AM
97-SC300
97-SC300's Avatar
Nice thank you for that
Old 11-09-11, 07:40 AM
LexusFTW
LexusFTW's Avatar
Maybe this will help
Attached Thumbnails How to route heater/coolant hoses with a 2JZGTE swap?-sc400-006-medium-.jpg
Old 11-09-11, 09:29 AM
97-SC300
97-SC300's Avatar
Thank you guys, so the hose from the back on the head goes to the side of the heater control valve, then the pass side heater hose goes to the lower part of the heater valve and the drivers heater hose goes to the line for the rear turbos.
joewitafro (07-27-23)
Old 11-09-11, 01:09 PM
LexusFTW
LexusFTW's Avatar
^Correct .
RLJ
07-24-15 07:17 AM
2jznosht
17
04-04-13 07:30 PM
Justin727
05-08-12 09:46 AM
dawizone
03-21-11 08:01 AM
TurboSCLex
07-31-03 06:47 PM
Quick Reply: How to route heater/coolant hoses with a 2JZGTE swap?
