mk3 supra halfshaft???
11-08-11, 03:02 PM
i looked in search. the problem with search i have to spend hrs to find an answer. and sometimes i still don't get a direct one..
so question is?????
can i use a mk3 supra front upper half of the driveshaft 5 spd na or turbo on a 1jz in a sc300/400?????
thank you for your replies people..
11-08-11, 03:30 PM
Quote:
Originally Posted by
megamax
so question is?????
Just to clarify.. you are swapping to an R154 as well?
You can use the front half off a Turbo MK3 and rear half off the SC3/400.
I don't think the MK3 NA models have an R154 so it will not work.
11-08-11, 04:06 PM
no not a r154 just a w58. and the w58 is off a 93 sc300.
11-08-11, 04:13 PM
MKIII W58 front half paired to a SCx00 rear shaft will work.
You'll have an issue with the carrier bearing, and you'll have to modify the mount to get it fit.
I'd just get a SC3 manual shaft, and call it a day though, however it will work.
11-08-11, 04:20 PM
Can't give you a definite answer. As far as I know the W58 trans have the same overall length so it SHOULD fit but I don't have any experience with it myself.
Edit:
There ya go!
11-08-11, 07:43 PM
thank you for your answers people.
11-08-11, 08:47 PM
just use the sc carrier bearing and youll be fine. I did it myself no issues at all
11-09-11, 01:45 PM
Not all MKIII driveshafts are the same length. The W58 and A340e shafts are the same. The R154 front half is shorter as the tranny itself is longer. So know which shaft you have.
11-10-11, 05:48 AM
it will not work you need the R154 MK3 front half .
the r154 front half has more teeth on the spline than the W58 that's why it will not work .
11-10-11, 10:11 AM
Wait, I thought he had a W58?
Davidb3232
Performance & Maintenance
01-25-16 03:55 PM
Boergy
11-20-12 09:37 AM
Jmcboost
SC400 / 300 Classifieds
11-01-12 06:14 PM
DoomLight
04-30-11 06:05 AM
speed6
01-18-09 12:33 AM
340 ,
driveshaft ,
forum ,
fourm ,
front ,
half ,
length ,
mk3 ,
mkiii ,
problems ,
r154 ,
rear ,
shaft ,
supra ,
w58
