92 Lexus SC400 starting then shutting off
Old 11-09-11, 02:12 PM
KDSC400
KDSC400's Avatar
Unhappy 92 Lexus SC400 starting then shutting off
The car starts then quickly shut off. In order for me to get it to start when it does this i have to rev the car for a few seconds and then the car will come on and stay on. After it is on there are no problems and it runs good. Sometimes the car will start up with no problem but for the most part i have to rev the engine for it stay on. I took it to a shop and they ran a diagnostics test and the guy said that it was reading a faulty front left O2 sensor. Could this sensor be the cause of the problem? also the no trac light is on and so is the check engine light.... they go on and off.
Old 11-09-11, 04:48 PM
Kira X
美少女戦士セーラームーン
Kira X's Avatar
Your fuel pump ECU is probably dying. I had the same thing happen to my 93 SC300 when I first got it. Here is a link on how to fix it: https://www.clublexus.com/forums/per...tures-faq.html
Old 11-09-11, 07:10 PM
KDSC400
KDSC400's Avatar
how should i go about soldering the wires?
Old 11-09-11, 08:17 PM
KDSC400
KDSC400's Avatar
im reading in these instructions that it wont work for a stock sc400 what does that mean?
Old 05-15-13, 11:38 AM
bags29
bags29's Avatar
Let me know if you found out how to solve this as I am having the same problem
Old 05-15-13, 02:47 PM
mickesanda
mickesanda's Avatar
It works very well for both SC400 and SC300. I've done it myself since i had exactly the same problem. However, you should be aware that doing this mod like it is described in the above mentioned thread will result in your fuel pump being turned on even when your engine is off, as long as the ignition is "ACC ON", e.g. while listening to the radio.
You can either change your fuel pump ECU (they are relatively cheap) or use a relay that is activated by the ECU.
/Mike
DNykoruk
08-08-17 12:06 PM
paco5150
21
03-09-15 05:18 PM
Markysc4
13
05-02-13 04:28 PM
Markysc4
04-17-13 11:41 PM
Quick Reply: 92 Lexus SC400 starting then shutting off
