Skew's SC400 GTE Build
My friend convinced me to have him record a few pulls, i figured i would post them up here. Im having an issue with my wastegate staying open at times. Also out of no where my passenger side low beam and high beam wont turn on. Wierd. I will look into the fuses and what others have done tommorow. Aanyone else have this problem
Thank you, its mostly a wastegate dump but i am running dual Vibrant mufflers. Sounds quiet until the wastegate opens lol. I really need to recirculate it back into the exhaust because its burning the paint off of the area the dump tube is facing.
Hey, thanks Steve. Yes, your right and i am definately on it. O.L.T is definately the man and he should definately change his name to Mr. D.I.Y. I have read a few of his threads and have the LED bulb sizes for the backlighting but dont know if i want to tackle the needles or send it off. I am going to read a few more of his threads tonight.
Side note: I also need my climate control screen fixed as well.
Just an update my car is still down i am sending my GTE in to be built and put a GE back in it.
AME Shallen CX
18x10 -6 fronts
19x10-16 rears
Fenders rolled and a little pull. The rears need a little more pull.
97+ conversion with lip
Dual tip single exit straight pipe exhaust
TSX Retrofit
Finally purchased my paint Metallic black with slight red pearl
wire tuck
quick release
nardi classic
Status Laguna Seats
Custom Guage cluster behind wheel
Stack ST8100 cluster
Contemplating on going with the TH400 swap or just a r154
Sorry for the ****ty cellphone picture but this is how she sits right now
AME Shallen CX
18x10 -6 fronts
19x10-16 rears
TSX Retrofit
wire tuck
quick release
nardi classic
Status Laguna Seats
1JZ Single SC400
Wow, thats a stretch on the rims and tires. I like how you acheived the swap. Be patient it will come on the build. Mine has also been slow but the results will be :-)
Progress:
50mm over fenders fitted just need a little more massaging. The body lines have a few gaps to clean up but i will get to it. 97+ tails sideskirts and front bumper fitted. A few other things but its coming along slowly. The first picture shows what a group of pot holes did to my tire.
