Transmission Fluid Black
Old 11-23-11, 04:52 AM
chonnytok
chonnytok's Avatar
Default Transmission Fluid Black
I got a 95 sc400 with 123k on it. I just bought the car and the transmission fluid is black. I was reading up on other forums and they're saying I shouldn't flush out my transmission fluid because it'll make my transmission run bad. Anybody know whats the best thing I should do? And how much quart of fluid could my sc hold up to?
Old 11-23-11, 09:07 AM
levie
levie's Avatar
well clearly your gonna need new fluid and filter, im sure you have realized this by now. why where they saying that if you where to flush it it would make it run bad?
Old 11-23-11, 09:13 AM
scshinobi
scshinobi's Avatar
I'm assuming they see it as loosening up all the dirt and cycling it through the trans will ruin it or something.
The fluid should be cherry RED. Flush it or change it up to you but I recommend a flush....
You already started reading on other forums, try to search a little more you will find a procedure with all the information you need.
Old 11-23-11, 09:22 AM
SC_coupe
SC_coupe's Avatar
With a simple drain and add plus filter replacement, you are actually only replacing about 1/3rd of the fluid, because most will stay in the torque converter. With a flush, you are able to replace all of the ATF in one shot. The argument against having a full flush done, is that when the ATF has deteriorated, sludge can form and by performing the full flush you *may* dislodge it and cause other issues.
Back when I originally bought my SC400 my transmission fluid was in a similar state (brownish-black) and needed attention badly. I had it fully flushed with no issues. The transmission behaved much better afterwords. It was about 10-12 quarts of Toyota type T-IV ATF from my recollection.
Old 11-23-11, 10:27 AM
OG Dada
OG Dada's Avatar
Here's what I did a few months back, LS and SC400's have the same tranny and engine.
http://www.lexls.com/tutorials/trans...ransflush.html
Old 11-24-11, 01:08 AM
chonnytok
chonnytok's Avatar
Thanks guys. What I did was just pour in 2 quart of transmission fluid because when I check, It seem like it barley had any fluid inside. I also changed my engine oil. But now my car shakes when I'm going about 30mph =\
Old 11-24-11, 09:45 AM
xspsi6
xspsi6's Avatar
The sc400 will only use oem type t-iv fluid and nothing else so if you used anything other than oem then that will create a problem.
Old 11-24-11, 10:30 AM
scshinobi
scshinobi's Avatar
check trans fluid when the car is warm. what fluid did you add? what color was it?
Old 12-08-11, 02:51 AM
chonnytok
chonnytok's Avatar
i forgot what brand i used but on the bottle it said made for toyota and lexus. The problem still continues, what i'm going to do is have it flush and pour in some new oil T_T
Old 06-19-12, 02:47 AM
chargerfan
chargerfan's Avatar
Let's do mine next month daniel!
Did you buy 12 qts?
Kalogerus
04-09-12 12:49 AM
jiodaqmke
20
07-19-11 03:30 PM
chinalfr
Hybrid Technology
07-18-11 10:26 PM
hugo2648
RX - 1st Gen (1999-2003)
06-20-07 11:18 PM
gapxguy
Maintenance
18
04-08-05 08:27 AM
Quick Reply: Transmission Fluid Black
