Invest in w58 and pray? or go r154 / v160
Old 11-28-11, 06:47 PM
SEXC
SEXC's Avatar
Originally Posted by Ali SC3
Even a Supra TT will loose some value if its heavily modified, as in you wont get back what you put into it unless you part it out and return to stock.
This is 100% true
To the OP if you're planning on keeping the car for a long time I recommend putting the v160. It is quite a bit more money but in the long run well worth it. If you go any other route you would just be wasting your money and not to mention the downtime. Once you have the right transmission your only problem will be keeping her hydrated (fuel) and rear tires from all those hard to resist spirited runs
ParkersDad
09-26-16 08:03 AM
Studiogeek
05-17-15 05:07 PM
Tabaka
31
09-16-13 05:01 AM
Quick Reply: Invest in w58 and pray? or go r154 / v160
