SC400 noob with power steering questions...
I've read these threads at length about power steering leaks and have seen both pump leaks asked about as well as hose washer leaks. Are they both issues with SC400s? (Update - I have my answer, thank you)
Not too sure about the 400, but buying an sc300 usually means you'll have to replace the ps pump. Whenever I spring a leak (mustangs and dsms) I try to clean up as best I can and keep an eye on it, checking before and after everytime I drive the car
