Using SC400 differential ring gear in Supra N/A diff?
Old 12-05-11, 02:53 AM
supraguy2
supraguy2's Avatar
Default Using SC400 differential ring gear in Supra N/A diff?
friend got info no longer looking.
Old 12-05-11, 03:03 AM
supraguy2
supraguy2's Avatar
Old 12-05-11, 05:16 AM
megamax
megamax's Avatar
Or just moved.
Old 12-05-11, 12:46 PM
supraguy2
supraguy2's Avatar
Ok well let this be teh thread.
Any help will be greatly appreachiated.
From what I understand yes it can be done, I just kind of want some confirmation since I am just going off reading. I don't want to have it wrong.
What I want is just to change the ring gear so then it becomes a 3.26 differential.
Old 12-05-11, 01:12 PM
BenStoked
BenStoked's Avatar
you'll need the ring AND pinion gears to make it work.
aside from that, should assemble, no problem.
Old 12-05-11, 05:41 PM
supraguy2
supraguy2's Avatar
and the ring and pinion gears will be the gs400 differential, which I can remove and transfer over to my Supra NA diff? correct?
I'm undecided if I should do that ^ or just put my LSD into the GS400 diff. It shouldn't make much of a difference either way? once its all said and done?
Old 12-05-11, 10:43 PM
supraguy2
supraguy2's Avatar
bump just trying to see if I got this right ^
I should mention that near future plans are single turbo and making 550whp.
Old 12-19-11, 08:29 AM
charley240
charley240's Avatar
There were 2 LSDs offered for mkiv supra. If I remember correctly yours is in fact a 10 bolt, if so then a gs400 ring gear and pinion will work. Search SF to find out if yours is 10 bolt or not. If it is the 12 bolt then it will not work
Charley
Old 12-19-11, 09:52 AM
Ali SC3
Ali SC3's Avatar
12 bolt is from the 6 speed only. the rest are 10 bolts and can interchange.
charley240
SC- 1st Gen (1992-2000)
08-02-11 12:16 AM
Boergy
15
12-17-10 10:37 AM
modifyd
01-07-06 08:06 AM
nuocmam122
12-14-04 11:10 AM
Quick Reply: Using SC400 differential ring gear in Supra N/A diff?
