Bee-r Rev Limiter wiring help! (2jz-gte)
i found a few installation manual on this unit for 1jz-gte but nothing came up for 2jz-gte.
does anyone have the wiring diagram to install the bee-r rev limiter into a 2jz-gte ecu?
Red = +B
Black = ground
Green = ?
yellow = ?
white = handbrake
Red = +B
Black = ground
Green = ?
yellow = ?
white = handbrake
Red - +12V IGNITION
Black - Ground (use a good chassis ground)
Yellow - IGf
Green - NE+
White - Secondary trigger wire*
*when this wire is grounded REV2 is activated.
2JZ-GTE
http://www.bee-r.com/main/rev/tekigo-t.htm
2JZ-GTE VVTI
http://revlimitter.blog110.fc2.com/blog-category-5.html
Keep in mind there are differences between USA and JDM JZS160/161
You will need to compare and confirm these wiring diagrams to a factory service manual for your chassis.
Good luck
Yellow - IGf
Green - NE+
2JZ-GTE
2JZ-GTE VVTI
Good luck
ARISTOLEX
GS - 1st Gen (1993-1997)
07-01-14 08:09 PM
