Anybody with a 4.7 swap?
Old 12-08-11, 12:05 PM
Arkansas
Arkansas's Avatar
Default Anybody with a 4.7 swap?
Been considering motor swaps since my 1uz has been giving troubles. Since people swap in a 2jz a lot on here, but been told the crazy amount of cash they had to drop.
Ran a search on the 4.7 swap, and not a lot of info on here. But seems like itd be a lot cheaper since there were a lot of tundras with the 4.7 on the road.
Heard u can mod the 1uz heads so u dont have to do a lot of new wiring.
Anybody have one they swapped into theyre sc4 and care to share?
Old 12-08-11, 03:32 PM
TLDriver
TLDriver's Avatar
http://www.lextreme.com/ they have a lot of info on the v8 stuff.
Old 12-08-11, 06:48 PM
Ali SC3
Ali SC3's Avatar
https://www.clublexus.com/forums/ls4...ottom-end.html
https://www.clublexus.com/forums/sc-...questions.html
https://www.clublexus.com/forums/sc-...otor-swap.html
I dont get why no one is swapping in complete 4.7 liter motors, instead of using the 1uz heads.
If its just for keeping 1uz ecu, why not just rewire to use the 4.7 ecu and harness instead of taking apart the block
The 1uz ecu is not very good anyways.
Old 12-08-11, 07:21 PM
Arkansas
Arkansas's Avatar
From what ive read, the 4.7 swap is easier than the 2jz swap and cheaper at that. Theres a company that makes parts for the UZ motors. They sell pistons, rods, crank shafts, cams, bearing, and a lot of other parts to give it power....even twin turbo kits and stroker kits to bring it up to a 5.7L
Old 12-08-11, 08:16 PM
Ali SC3
Ali SC3's Avatar
yeah they are great motors it just costs a whole lot more cause you have to build the motor if you decide to do a hybrid uz engine. If you can just drop in the whole 4.7 as is then you may be right about the cheaper part.
its all about personal preference really, a 4.7 with a TRD supercharger would make a nice daily driver.
Old 12-08-11, 10:16 PM
Arkansas
Arkansas's Avatar
To do the drop in, ud need different motor mounts, and have wiring for ecu and stuff done
Rjame
10-31-17 01:31 PM
rawfish
Performance
04-25-12 11:36 AM
vishal25pm
Performance
12-15-10 10:58 PM
Mr.NA_T
02-10-08 01:25 AM
Luke_in_SD
SC- 1st Gen (1992-2000)
18
01-15-08 11:48 AM
Quick Reply: Anybody with a 4.7 swap?
