1jz VVTI swap info, a few questions.
I was blessed with a offer to buy a VVTI 1jz for $500 today from a friend. I need info on the VVTI swap. He said I will need the turbos for it which to me shouldn't be terribly hard to come by. However, I have been warned that doing the vvti 1j in the sc is no where near as easy as the non vvti. Can anyone explain this to me?
First off, the 1jz vvti, came with one single turbo, oposed to the twins from the older model 1jz. Depending if you have a soarer 1jz vvti rear sump, or a front sump from a chaser or other model front sump. If you have a soarer rear sump then won't be as difficult, front sump chasers have diff harness plugs
