Turbo 4.8 LSx SC300 - 509wrhp @ 12psi
#31
I wish I knew a shop that would do this for a mk3 Supra NA. My brother is dying to find someplace that will do an LSX engine/trans (auto) swap in his 89 Supra. The turbo would just be icing on the cake. We were already considering the 5.3 since it's cheaper than the LS1/2 and any v8 would make that car a great cruiser. The 4.8 never occurred to me.
Plan B would be a 1UZ since they're even cheaper, and other than the physical mounting the rest would be pretty simple to do, even if it's "only" 250 hp. A 1jz/2jz is not an option; he's already had a Mk4 Supra so this one needs to be different.
#34
Thanks!
Thanks! just curious, why do you think a LS1 would be better?
#35
I was gunna hate a little with the GM engine, but this is the best thing in this whole thread!
Minus the awesome 500+ hp with a "Mid-west Plateau" torque curve! Good job!
![EEK!](https://www.clublexus.com/forums/images/smilies/eek1.gif)
#36
A lot more of you people should be routing your W/G's into the exhaust too, your are killing that sweet compressor song!
Minus the awesome 500+ hp with a "Mid-west Plateau" torque curve! Good job!![EEK!](https://www.clublexus.com/forums/images/smilies/eek1.gif)
#44
I am bumping this up!
Op i have been thinking about this Swap on another SC i am picking up in couple days , I was wondering how much wiring is involve? What ecu are you running? my car is manual car and i would like to keep it manual so what setup do you think will bBB ?It is going to be Boosted at the same time.
Please shed some lights, on what oil pan you are using? etc.. Thanks in advance.
#45
I started off running a truck pan, it fits great but hangs too low. I am swapping to a H3 pan. Right now I have the motor out - doing a cam swap, dual springs, LS9 head gaskets, head studs, and a few more mods.... The reason I pulled the motor was to paint the engine bay, install AC, and clean up some misc stuff that I rushed.
Once its all back together I just need to finish up hooking the cluster up. I always monitor with EFILive so I never got around to the gauges (other than the tach).
Hope that helps, let me know if you have any other questions!
Thanks,
David
Lanceezy
Performance & Maintenance
10-14-09 09:46 AM
