Neutral Safety bypass problem
#47
Interesting regarding the wire you added. Can you tell me what pin it was on IK2? I am curious. As far as the bucking and stalling, I would remove the SAFC2 and get it running without it and then add it back. 9 times out of 10, the tuning device is the problem. Your car should run fine, if slightly rich with the 550s. Did you put a new O2 in with the swap? I had some idle and driveability issues that ended up being a failing/slow O2 sensor.
#52
have not had the chance to do anything on it yet, it starts up fine, idles perfect, air/fuel ratio fully warmed up is at like 13.5, but if i try to rev it at all it bogs down, a/f's go crazy low, and it stalls out.. i checked my safc2 and its hooked up properly, its a brand new unit, i have it on pressure, 6 cyl, throttle up, 01 in and 01 out for the sensor. when i go to sensor check on the safc and to monitor, my throttle % shows 13.5-13.9 at idle with foot of the gas and anytime i touch the gas it goes to 100% right away, not sure why its doing this, i tried to initialize the unit multiple times, maybe my Thottle position sensor is out of adjustment, its a brand new sensor..
#55
Not sure if I can link to SF but here goes...I would post up a CL link, but I don't think anyone wrote this up here on CL...
http://www.supraforums.com/forum/sho...ght=tps+adjust
Oh, and disregard the second part of his instructions steps 3 and 4 that use the .016 and .019 feeler gauges. That is for the SUB TPS.
#57
Not sure. Is the car warm? My car idles low once it's fully up to temp. Around 550-600rpm. It idles up when cold to around 1200rpm and gradually drops as the car warms up. If the ac is on the car idles around 800-900rpm. I imagine a tps adjustment being off can cause some serious idle issues, so adjust it and go from there.
