Wont Start...after replacing components that have nothing to do with it.
Old 12-19-11, 08:57 AM
Tofubento
Tofubento's Avatar
Default Wont Start...after replacing components that have nothing to do with it.
I recently replaced, water pump, timing belt, acces belt, as well as HBPulley, and now it wont start. It sounds like it is trying to turn over, but wont. I have yet to test starter or anything else, but I dont see why it would have issues starting , when it started perfectly fine before.
Anyone have any ideas why, or how this happened, or have had this happen to them?
Old 12-19-11, 09:28 AM
Justinizme
Justinizme's Avatar
Are you 100% positive you put the car back in correct timing before buttoning it all up? Are you sure one cam isn't off on the timing belt?
Old 12-19-11, 10:06 AM
Tofubento
Tofubento's Avatar
top dead from the get go. So I am a bit lost as to why this is happening. When pulling water pump, I did pull alt and dist, but tossed them back in correctly. I have yet to run into this problem with any car after replacing the parts that where replaced. Doesnt hurt to try it again , ill rip it apart and try it again.
Old 12-19-11, 10:38 AM
Tofubento
Tofubento's Avatar
oh man, that was the problem. I guess it wasnt fully at tdc when I was throwing the full pump back on and started putting it all back together. I didnt even think about it. Thanks for the help me. Cant believe i didnt check that the first time around lolol
Brucelee28
02-07-18 11:26 PM
Slvr surfr
09-20-10 11:00 PM
Josh S
02-05-08 07:20 PM
Felix gs43
Performance
10-08-06 10:31 PM
95SC400
12-28-04 09:16 AM
Quick Reply: Wont Start...after replacing components that have nothing to do with it.
