Help! Gas/Fuel in Throttle Body
Hello CL Family-
I recently replaced the starter on my 92' SC400 and ran into an issue. The car has a rough idle, rich smell (thick smoke), and gas is leaking into the throttle body. I've removed everything twice, checked all the connections, replaced all gaskets with ones from the dealership, ECU, fuel pump ecu mod, replaced IAC, TPS, MAF, and PCV valve. My spark plugs continue to foul which I'm assuming is from the extra fuel. I am lost as to what could cause fuel to be dumped into the throttle body. Any input is greatly appreciated.
Thanks!
Thanks!
The easiest way honestly is to take a screw driver and stick it on the injector and put it up to your ear with the car running, you should be able to hear it fire quickly and feel the vibrations.
You could also stick a test light on the harness of each one and see if it fires that way as well.
I have never worked on the 1uz, but it sounds like your fuel pressure regulator could be bad. If the regulator fails internally, it can allow fuel to be sucked right into the vacuum lines. You can check the regulator by getting a hand vacuum pump, attaching it to the FPR vacuum nipple, and verifying that it holds a vacuum.
Or, the old school method is to put a piece of vacuum hose on the regulator and suck on it. If you get a mouthful of fuel, it's bad You may get lucky and see fuel drip from the vacuum line when you unplug it from the regulator...
update:
so today while I was troubleshooting using the advice from my fellow members, I noticed the upper intake manifold was building up condensation. When I touched it, expecting it to be hot since the car was running, it was ICE COLD. It felt like the outside of an a/c line. Anyone ever experienced this?..
Thanks for the quick reply stockhatch. Another piece of info.. when I removed the upper and lower intake the first time, I found a nut wedged between one of the valves. Also, could the cold start injector be malfunctioning? Didn't really see too much info on it when I did the search for it.
Actually that's what I was going to say. The Cold Start Injector doesn't really come on until like below 40 degrees farenheit. Don't quote me on that though. The line the back is for the CIS. But it's actual location is under the intake manifold.
You could always just squeeze the line and I'm sure that would stop it from coming on.
Have you tried putting it in diagnostic mode yet?
They were all built at the same time so it's no surprise that they all would have leaking caps at about the same stage. I'm having mine rebuilt instead of buying another used one.
It's just like the needles - used but working just means they'll die soon anyway.
