1jzgte uses a stock sc300 driveshaft correct?
Old 12-23-11, 08:55 PM
xspsi6
xspsi6's Avatar
Default 1jzgte uses a stock sc300 driveshaft correct?
As in the whole thing from the trans to the diff? Even if it's in a sc400 chassis in my searches it seems ro be the answer is yes but would like confirmation 100% .
Old 12-23-11, 10:00 PM
xspsi6
xspsi6's Avatar
I forgot to mention that it's an auto.
I am trying to figure this out to help a buddy finish his swap.
Old 12-24-11, 05:22 AM
Biggu
Biggu's Avatar
with what trans,
with a w58 you use your stock one
with a r154 you use a supra r154 front and sc300 rear or a true soarer.
Old 12-24-11, 07:46 AM
xspsi6
xspsi6's Avatar
It's an auto trans.
Old 12-24-11, 09:22 AM
chingpo05
chingpo05's Avatar
if the rear of the trans is a female then it will use the stock ds. if its a 3 bolt then idk gl with it. i think some ppl were talking about the sc4 ds and rear diff
Old 12-24-11, 11:00 AM
megamax
megamax's Avatar
so to correct this?? i have a w58 iam using on my sc400. iam putting a 1jz in it. so i need a mk3 supra front halfshaft and i can use my sc400 rear shaft to work??
or can i use a sc300 auto full driveshaft??
Old 12-24-11, 03:28 PM
xspsi6
xspsi6's Avatar
Last auto 2jzgte /aristo swap I did we used the sc400 drive shaft and the 3 bolt flange off the sc400 trans and bolted it on to the aristo trans.
I did a 1jzgte 5 spd swap in to a 5 speed sc300 and all we needed there is the mk3 supra front half of the ds.
Auto 1j I have never done before so this is the reason for the ?
Old 12-26-11, 04:43 PM
xspsi6
xspsi6's Avatar
Anybody here done an auto 1jz swap that could chime in?
Also the motor mount brackets look the same as an sc300 is this infact true?
Old 12-26-11, 05:45 PM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
The motor mounts and brackets are the same. I just bought some for the 1jz and the R154.
Old 12-28-11, 08:55 PM
xspsi6
xspsi6's Avatar
Ok thank you now I just need to confirm that the driveshaft from an auto sc300 will indeed work as I believe it does.
Old 12-28-11, 09:05 PM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
I believe that will work also. I had to reread everyones reply to make sure they were correct. I know that the SC400 driveshaft will NOT work for the 1jz or 2jz with a manual tranny, either the W58 or the R154 or the V160. Since you are keeping the auto the stock SC300 should work. Contact ryanv by PM and confirm or search in his thread in his signature. Most of the pictures wont come up but the answer might be there. I dont want to lead you astray unless I am 100 percent correct.
Old 12-28-11, 09:08 PM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
Oh yeah some people will tell you to get the TT mounts also. They will work as long as you have the stock brackets. I found out the hard way that long brackets will NOT with long mounts. Short mounts will NOT work with short brackets. You have to switch them up or mix match. Long with short and vice versa. Hope this makes sense. A lot of typing from a cell phone. :-)
osomegaSC
01-15-17 05:53 AM
Jrlewis05
SC400 / 300 Classifieds
07-16-15 03:47 AM
visi0n
SC- 1st Gen (1992-2000)
05-12-10 02:48 PM
na4now
03-14-10 12:15 PM
GReddySetG
04-21-06 01:02 PM
Quick Reply: 1jzgte uses a stock sc300 driveshaft correct?
