View Poll Results: which fan are you using/happy with
electric fans
14
43.75%
stocker clutch fan
18
56.25%
Voters: 32. You may not vote on this poll
clutch fan or electric fan???
Old 01-01-12, 09:53 PM
INTIMAZY
INTIMAZY's Avatar
Originally Posted by Ali SC3
Its an OEM Toyota part designed for a 2jz, its a perfect match. they are pricey however.
Rockauto apparently has IS300 OEM replacement shroud and fans for ~$130. Thoughts? If that's all we need besides a controller this doesn't seem pricey at all.
Old 01-02-12, 11:32 AM
cartmill
cartmill's Avatar
Originally Posted by LEX_MAN
Although i like more mechanical equipment in my car, the fan i chose electrical, because it gives me more control. I usually don't even turn them on unless i'm parked for over 20 minutes in 100 degree weather.You guessed it,its an N/A
you know the fan clutch basically free spins until it reaches ~190* right? i mean the damn things are bulletproof, and they flow a **** load of air.
have you ever forgotten to turn on your e-fans and let your car overheat idling? i have.
Old 01-03-12, 08:54 AM
Luv2xl
Luv2xl's Avatar
I would confirm this is a complete unit with fans, motors, and reservoir for that price.. too good to be true and we all know about the saying...
Old 01-03-12, 10:29 AM
INTIMAZY
INTIMAZY's Avatar
LX3115108 appears to be the part number for the whole assembly so as far as I can tell the price it legit at ~$130.
The shroud alone with reservoir is ~$80 bucks.
Old 01-03-12, 01:24 PM
Ali SC3
Ali SC3's Avatar
If its the whole thing for $130 I would buy one, they seem to go for about $300 unless you get a good deal.
why are people manually turning their e-fans on and off.
thats why you get a fan controller or a cheap thermostat controlled relay.
Old 01-15-12, 10:56 PM
WadeLovell
WadeLovell's Avatar
$130 looks great especially at 188k when the fan clutch is dying.
Old 11-03-13, 06:21 PM
Jewzyj
Jewzyj's Avatar
Thumbs down what a tool
Originally Posted by Wicked SC
I'm running electric fans but it's only to clear up the clutter up front so my chrome pullies are not being blocked. I also only drive my car about 4-5 times a month..
IMO, nothing cools better than OEM so if you're looking for the best cooling option, I would say to keep your Fan Clutch. That's just my $.02..
oh not even a quad core rad with 2000cfm fans what a dumb statement im sure drag cars have oem cooling
Old 11-03-13, 06:26 PM
soarer13oy
soarer13oy's Avatar
Voted for clutch fan never had an issue.
Old 07-10-15, 09:16 PM
megamax
megamax's Avatar
bumping this back up, again.
so since I got my ac installed I need something with more ummph. these are dual 14" fans from advance. so I need more cfm's to support my ac usage at initial startup.
Old 07-21-15, 09:04 PM
1997Soarer
1997Soarer's Avatar
For reference. Some info I pulled off of Supraforums a couple years ago.
2JZ-GTE clutchfan pulls 3600cfm at 1800rpm. At that rpm the fan clutch slips so that cfm is constant from that rpm up.
2JZ-GE clutchfan pulls 3300cfm at supposedly the same rpm. Differences in the cfm is due to the different shapes of the GE and GTE blades
So if anyone is considering electric fans, the idea is to get a similar cfm.
Old 07-26-15, 06:45 PM
Krednjen
Krednjen's Avatar
Mechanical fan clutches eat up enough horsepower to make a real difference on a 100 hp car. Not so much, on a 300 hp car. Also, Volvo fans are bada and look great in my experience.
Old 07-27-15, 03:37 AM
lexforlife
lexforlife's Avatar
Is300 fan setup with phr aluminum shroud controlled with relays either using 2 temp probes for on off temps or completely controlled by ECU ,problem solved... in all the years I've been working on Lexus cars , I have yet to see these fans fail ..they flow more cfm then fan clutch setup.. if car is boosted and running multiple pumps , gauges, you will need to upgrade alternator and associated wiring... dexlex has this setup in his 800hp ish supra and I have watched via pro efi can -bus gauge temps drop 15 degrees within seconds when fan went on
I have same setup ready to install to rid myself of the ugly power robbing clutch setup, I am also using a mechman 170 amp alternator with phr alternator rewire kit, also buy the fans off eBay and get 2 of the 5 blades .. usually find them for less the 75 each and if you don't want to spend the money for phr shroud ,use the OEM shroud , with slight modification, will mount to your radiator .. I have one already modified can sell for cheap as I have the phr shroud already
Old 12-21-16, 04:04 PM
SEIDO
SEIDO's Avatar
What's wrong with a fan that runs all the time (belt-driven)?
Old 12-21-16, 04:54 PM
nuturf87
nuturf87's Avatar
97 or 98 Ford Taurus fans are best. Owned couple foxbody mustangs. They never went out on me. Ever
Old 12-22-16, 12:15 PM
salimshah
salimshah's Avatar
Received 1,096 Likes on 986 Posts
Belt driven has no gearing ... due to fan clutch, based on ram effect the fan can float and spin faster when your vehicle is traveling fast [other wise it would start to restrict the flow in the shroud]. Also engine (really fan position) in the shroud becomes critical. SC has a long nose and the space between the radiator and the engine block is quite a bit.
Electric set up is typically by 2 fans, where the second kicks in when there is additional demand on cooling. Electrical motors do tend to produce electrical noise, which can be picked up by the audio system.
Hydraulic in SC provides gearing (2 speed) with no electrical noise and the spacing is not an issue.
My humble guess is that Lexus engineers decoupled the position of the engine and locating the fan in the middle by going hydraulic and enjoy the benefit of gearing (2 speed) and no electrical noise.
Salim
GKLCPA
22
12-20-13 05:02 AM
SC3Monster
06-07-13 05:23 AM
deanbrown
09-22-12 12:14 PM
MumRah
26
03-29-12 07:19 AM
SOARERSONZ
SC- 1st Gen (1992-2000)
19
09-23-11 10:16 AM
Quick Reply: clutch fan or electric fan???
