Sc300 NA-T build
Old 12-25-11, 09:00 PM
2JTsc300
2JTsc300's Avatar
Default Sc300 NA-T build
Could I run a aem fmic with the stock ecu without using a standalone and make good power?
Old 12-26-11, 05:09 AM
lexforlife
lexforlife's Avatar
simple answer is no.. stock ecu has zero look up maps beyond atmosperic pressure .. makes stock ecu go ape ___ at the wrong times .. you want a true na-t to work and be reliable standalone is required
look at my sig for power levels and i still have the original 15 yr block in car and i drive it everyday and been boosted 4.5 yrs
Old 12-28-11, 06:44 PM
98$c300
98$c300's Avatar
Nice hp Ed 701!!!!
Old 12-28-11, 07:33 PM
Nova
Nova's Avatar
ed ur not running 103 octane daily are you?????
Old 12-31-11, 08:36 PM
RichKid79
RichKid79's Avatar
stock ecu? u need at least an emanage ultimate. dont go cheap with a SAFC, youll gain an extra 20hp with just a good computer. or even better go megasquirt (assuming you have a really good tuner)
Old 01-02-12, 11:38 AM
cartmill
cartmill's Avatar
dude he said AEM FIC, which is basically the same thing as the e-manage.
Old 01-02-12, 01:39 PM
RyanV
RyanV's Avatar
Isn't aem fic for OBD2 cars and not compatible with the karman vortex sensor?
Old 01-03-12, 07:23 AM
cartmill
cartmill's Avatar
good question. is that true? i've always been a standalone EMS guy.
fwiw, i was thinking of the 95+ MAFs, not the earlier karmans
Old 01-03-12, 07:56 AM
TweakTech
TweakTech's Avatar
The F/IC has an onboard MAP sensor. It can work with OBD-I, or OBD-II cars.
Old 01-24-12, 07:35 PM
2JTsc300
2JTsc300's Avatar
i just got my AEM EMS in the mail. installing it as soon as i get my MAP and IAT sensors in the mail.
Old 01-24-12, 09:52 PM
lookEVO
lookEVO's Avatar
Came in expecting pics of turbo... everything went worse than expected.
Old 02-12-12, 08:33 AM
XplicitlyR
XplicitlyR's Avatar
Do you have everything installed yet? That is the same setup I have, if you need help let me know, I can come by or you can come over and we can install it at my house.
Old 02-12-12, 09:14 AM
broda805
broda805's Avatar
nice! standalone ftw
Jd1982
01-05-19 03:35 AM
Sc300mk4
03-14-18 03:28 PM
2jzcrazy
02-19-14 11:29 AM
joshmannin
Performance
03-02-12 06:14 AM
kmn5
06-21-03 10:58 AM
Quick Reply: Sc300 NA-T build
