Fuel System Picture Thread
Old 12-27-13, 06:13 AM
  #31
97-SC300
97-SC300's Avatar
do I cap the line inside the gas tank that has a small hose attached to it to the oem fuel pump hanger?
Old 12-27-13, 07:27 AM
  #32
INTIMAZY
INTIMAZY's Avatar
What are you guys using to cap the inside? I used gas tank putty crammed as deep inside the hardline as I could then pinched down the end of the hardline with pliers. I actually did it on both ends of the hardline.
Was afraid to use a rubber cap inside a harsh fuel vapor canister.
Old 12-27-13, 10:16 AM
  #33
97-SC300
97-SC300's Avatar
any one know the thread size on the banjo bolts under the tank for the lines?
Old 12-27-13, 01:41 PM
  #34
99SC42
99SC42's Avatar
^^ I told you what to do you are chasing your tail lol.
When you remove the banjo bolt the flange has a dowel pin and that has a hole in there, so if you take the line off and get a bolt it will still leak fuel because the dowel pin on the line is missing since you just have a bolt in there.
i've been there.. pulled atleast 8 different SC tanks and they all have that.
Do it like i told you..
Old 12-27-13, 01:58 PM
  #35
Piraiba
Piraiba's Avatar
I agree with Omar. Only other way around it is doing the Zini mod and you don't want to go there. Trust me.
Old 08-01-14, 06:09 PM
  #36
sc300bigtx
sc300bigtx's Avatar
Bump what ways did some of y'all remedy eliminating the stock lines I already have new feed and return lines ran just need an idea or really an example of way someone's done it
Old 04-27-17, 10:00 AM
  #37
megamax
megamax's Avatar
bumppers!!!
menty
06-12-21 05:01 PM
motorheaddown
03-30-17 08:07 PM
brett14
03-15-17 05:57 PM
pacerdonfl
02-27-16 01:31 PM
Quick Reply: Fuel System Picture Thread
