Anyone converted to TT ecu before going turbo?
Has anyone ever converted to a TT (aristo or supra) ecu with the appropriate hardware (injectors, map sensor, IAT, etc) in preparation for going turbo but remained NA for a period of time? Is this a horrible idea?
I was thinking I'd like to convert to a TT ecu and go coil on plug to delete the distributor in preparation for going turbo, but run it NA for a little while.
Thoughts?
Thoughts?
It should work fine, the ecu does not care if you boost or not, but you may run a bit richer than normal though at WOT cause you will have less airflow than normal at that load (0 psi).
Not many people run the TT ecu on na-t's so I doubt you will get much first hand info, but It should run just fine and is a good idea to get your ecu and ignition sorted out so you can have fun when its turbo time.
well the general consensus seems to be don't run the NA ecu at all when boosted, so yes, they have a TT ecu retarding timing or a standalone that is tuned properly.
Studiogeek
SC400 / 300 Classifieds
08-03-18 10:16 PM
Studiogeek
SC- 1st Gen (1992-2000)
07-10-15 05:05 PM
