Aristo swap problem revving up
Old 01-03-12 | 10:41 AM
stockhatch's Avatar
stockhatch
Did the map check out from that test I linked?
Old 01-03-12 | 10:43 AM
97-SC300's Avatar
97-SC300
Yes it did
Old 01-03-12 | 12:08 PM
stockhatch's Avatar
stockhatch
Sounds like ECU then, unfortunately. There is not really anything else to check if the TPS and MAP sensors check out.
Old 01-03-12 | 12:20 PM
soarer13oy's Avatar
soarer13oy
You can double check your vac line to the map sensor. My car ran like crap when i didnt run the map sensor vac correctly. I also had a similar problem when i first finished my swap, but the problem was that i had a boost cut controller and did not give the 12v to the controller. Im not sure if you have the bcc, but its just something i ran into.
Old 01-03-12 | 12:33 PM
97-SC300's Avatar
97-SC300
dont have a bcc, could you tell me the correct way to ran vacuum to the map sensor? maybe a picture of how it should be connected and to what
Old 01-03-12 | 12:34 PM
97-SC300's Avatar
97-SC300
im thinkning the reason i had the 31,41 codes is because i had the MAP and TPS disconnected with the key in the ON position while testing them...
Old 01-03-12 | 12:58 PM
soarer13oy's Avatar
soarer13oy
This is how i have it. Try reseting the ecu and see if youll have any codes after a while. Im sure you got those codes from unplugging them.
http://www.97supraturbo.com/Tech%20s...es%20forum.jpg
Old 01-03-12 | 01:20 PM
97-SC300's Avatar
97-SC300
Hmm, i dont think i have any vacuum switching valve connected to the fuel pressure regulator, i have a vacuum line from the regulator to the sensor streight. This looks like a usdm version. Its all different
Old 01-03-12 | 01:44 PM
stockhatch's Avatar
stockhatch
Yeah your JDM stuff won't have that VSV. At least mine didn't.
Soarer|3oy, that's a good idea to verify vacuum source at the map.
OP, you should have a T in the line that connects the FPR to the MAP to the "gas filter" screwed into the intake manifold. If you just have a single line with no T going from the FRP to the MAP, then that is your problem for sure. No vacuum signal!
Old 01-03-12 | 01:47 PM
97-SC300's Avatar
97-SC300
I do have a "t" in the line the connects to the fpr to the map to the gas filter thats screwed into the manifold. Could you guys post a pic of yours just so i can verify again
Old 01-03-12 | 01:48 PM
soarer13oy's Avatar
soarer13oy
Everything is basically the same as the jdm, but without the egr and the vsv at the fpr. Has dr tweak said anything about your issue?
Old 01-03-12 | 01:56 PM
97-SC300's Avatar
97-SC300
no he did not, just said to check voltages at the TPS and the MAP which are good.
Old 01-03-12 | 01:58 PM
stockhatch's Avatar
stockhatch
It's freezing here, but I did walk out earlier and verify that is how mine is plumbed. To verify you have actual signal, can you pull the vacuum line while the car is running and check it with your finger for vacuum? I don't know if the car will die when the MAP looses vacuum signal, but you should do whatever you have to do to verify there is no blockage in that vacuum line.
Old 01-03-12 | 02:05 PM
soarer13oy's Avatar
soarer13oy
If you unplug the map vac the car will change in idle and eventually stall out.
97-SC300's Avatar
97-SC300
ill check that later thanks guys, ill keep you updated
