1JZ/2JZ Oil Catch Can Questions
Old 05-15-14, 12:06 PM
  #46
99SC42
99SC42's Avatar
lOL How does it catch fuel?
No it's not normal lol, shouldn't catch no fuel..
Old 06-10-14, 01:14 PM
  #47
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
Bumping old thread.
After nearly two months of waiting, I finally received the JDL catch can. Let me be the first to say what high quality it is. The wait was kinda long but the quality of workmanship is top notch. I had to move the ABS pump from the factory bracket and move it inward. The one they used for test fitment did not have this. After speaking with them again, they wanted me to send it back so they could correct the problem. I was against it. Due to it taking almost 2 months to receive. I decided to make it work. I ran the drain tube down the factory hole under the pump for easy access. I also had to redo all the braided lines with new fittings. Overall a much better and cleaner setup than before. No more wye fittings and this can adds a vacuum intake.
Old 06-11-14, 07:13 AM
  #48
Ali SC3
Ali SC3's Avatar
Looks great, that should work much better!
Old 06-11-14, 02:39 PM
  #49
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
Thanks Ali. No more smell inside the cabin either, now that it is routed through the intake and out the exhaust. Worth the wait.
Old 03-14-15, 07:08 AM
  #50
kez
kez's Avatar
Bumping this thread since it needs more photos
I need to do an oil catch can setup since I'm getting that oil smell in the cabin
Post up some pics and specs of you Catch can setups
Old 04-17-16, 10:45 PM
  #51
megamax
megamax's Avatar
word I need some visuals also!!
Old 04-18-16, 04:53 AM
  #52
gerrb
Super Moderator
gerrb's Avatar
Jim -- not hard.. get the right Catch Can with baffles inside if you want to reroute one line back to the intake infront of the turbo.
Many will put a line from each valve cover to the catch can and there is a filter on the catch can. That basically is catching all the blow by into the can and letting the pressure from the crank case out into the filter.
If you want a better setup , get a real good catch can that has a good baffles design inside. It has a third fitting where you connect a line from the catch can to the turbo intake pipe. It does help in scavenging ... or even pulling pressure out of the crank case. But make sure it is a good catch can that separates the blow by liquid .. that stays into the catch can and only air / pressure is pulled back into the turbo intake or you will be pulling liquid back into your turbo / IC and into the intake which defeats the purpose of the catch can and scavenging ..
Old 04-19-16, 01:55 PM
  #53
CatManD3W
CatManD3W's Avatar
JDL Auto Design can designed for SC...
Here is mine installation pics...
-10an line from each valve cover......and a 1/2 NPT to -10an 90 degreee fittings....you will need to tap valve covers out of have a bung welded on. I choose to tap mine because valve covers were already powdercoated.
Used the open end for K&N breather air filter...some people run it to intake on turbo....but I choose to do it this way.
Old 03-05-17, 12:46 PM
  #54
megamax
megamax's Avatar
bumppers! as I just completed my 1.5jz build yesterday morning and got it started up..
I have "faint" white fumes coming from the filter. I'm going to run a vac line from the catch can to the pcv valve location on the intake next. here is the mod ive done to a cheapo ebay cc.
Old 03-07-17, 02:47 PM
  #55
Ali SC3
Ali SC3's Avatar
should work out, but be careful with that clear hose on the side, they can leak randomly.
Old 04-18-20, 06:10 AM
  #56
bbyatv
bbyatv's Avatar
I am just finishing up my NA-T build and am reading a lot of varied opinions on catch can designs.
I am thinking about going with something that looks like the schematic in the attached image below. Does this make sense?
In this setup, would I remove the PCV valve and then use the vacuum port on the intake manifold for some other purpose? I am guessing I would.
Also, would the catch can be vented? That would seem to defeat the vacuum created by pull from the turbo intake pipe.
In this setup I would have to use a very good catch can so as not to have oil/moisture entering the turbo. Any ideas on a good one (brand/model) for that purpose?
Any help is much appreciated as there is a lot of confusing information out there.
I really want to keep some vacuum to help with scavenging.
Bruce
Attached Thumbnails 1JZ/2JZ Oil Catch Can Questions-catchcanplumbing.jpg
Old 04-18-20, 06:21 AM
  #57
bbyatv
bbyatv's Avatar
Just found this thread that seems to support my thinking. Just need to figure out what catch can brand/model to use.
http://www.ozhonda.com/forum/showthr...n-intake/page2
Bruce
Dtaylor3
Build Threads
34
11-09-21 07:50 PM
SC3NAT
07-23-14 09:26 PM
Armyof1
Build Threads
49
08-21-11 06:51 PM
joeazy187
SC- 1st Gen (1992-2000)
08-24-10 07:50 AM
soko420
RX - 1st Gen (1999-2003)
08-15-09 07:39 PM
Quick Reply: 1JZ/2JZ Oil Catch Can Questions
