Timing Belt is RUBBING
Old 01-02-12, 06:57 PM
XplicitlyR
XplicitlyR's Avatar
Default Timing Belt is RUBBING
Was about to do the 92+ 4Runner dizzy cap swap and when I removed my timing belt cover I found this.
Old 01-02-12, 07:01 PM
XplicitlyR
XplicitlyR's Avatar
I just had the head gasket changed last week, I went back to the pics and this is what I found
Old 01-02-12, 07:02 PM
XplicitlyR
XplicitlyR's Avatar
After tearing it back apart, this pin backed out, It had to be hammered back in, and I don't know why it came out, any IDEAS?????
Old 01-03-12, 12:08 AM
Photon440
Photon440's Avatar
What does that pin do? Could you have just pulled it out all the way and discarded it?
Old 01-03-12, 05:58 AM
RyanV
RyanV's Avatar
Wow, that just sucks! It that an alignment dowell?
Old 01-04-12, 09:59 PM
XplicitlyR
XplicitlyR's Avatar
It's all back together, I was told its there to block the belt from slapping the cover when it wears out and stretches, It must have got bent in when the cover/head was put back together.
It was bent back out and I have put 40 miles on the car, everything is good now.
Old 01-04-12, 11:01 PM
lookEVO
lookEVO's Avatar
It looks like it dug into the belt a lot man... i wouldnt trust that belt like that. You need to change it. It has a built in failure now.
Old 01-16-12, 10:45 PM
XplicitlyR
XplicitlyR's Avatar
Thanks for your concern. When I said its all better now, I ment the shop that did the headgasket picked the car up from my house changed the belt and brought it back the same day. Great service.
thatoneazn
08-29-20 01:02 AM
razvy
04-20-19 08:14 PM
RemSteele
SC- 1st Gen (1992-2000)
17
06-27-11 10:33 PM
JeffTsai
02-17-08 05:27 PM
Quick Reply: Timing Belt is RUBBING
