DIY: Ford 8.8" Differential Swap
Old 01-04-12, 03:26 PM
LEX_MAN
LEX_MAN's Avatar
You slowly creeping towards domestics my man
I always like your threads, keep on doing what youre doing .
Old 01-04-12, 03:34 PM
1siksc
1siksc's Avatar
I say nothing! or like the famous car stickers "nuff said"
it's been done before, sucks that i'm not the first to it. Here it is in a supra.
Old 01-04-12, 06:23 PM
BenStoked
BenStoked's Avatar
got more info on the axle/hub portion of the swap?
Old 01-04-12, 06:36 PM
Ali SC3
Ali SC3's Avatar
Originally Posted by INTIMAZY
Lots of choices of pretty much the same ratio besides that 3.26
Jumping from a 3.7 to a 4.2 isn't much of a leap. Ford gears go from 3.08 to 5.13
True, for most of the popular combos those numbers would give you the gears you want, but if you need really custom then yeah you would need to swap. You have me wondering what 5.13 would feel like.
Old 01-04-12, 09:39 PM
1siksc
1siksc's Avatar
5.13 would be crazy, i'll keep updating as i find more out, hopefully i'll have it bolted in not to distant from now.
Old 01-06-12, 08:55 PM
boosted4.6
boosted4.6's Avatar
Don't listen to the naysayers. Your on to something. If you make up a "kit" and take your time to make a jig, I'm sure you will have people wanting to buy it. I would. I just put an LS1 in my Sc and beech another option other than 6spd tt LSD
Old 01-06-12, 11:03 PM
INTIMAZY
INTIMAZY's Avatar
Having a 3.55 option would be mint. It bothers me that I cruise on the highway (75ish) at so close to 4000 rpm with my R154 + 4.08 rear. I know Toyota is OK with it so it must be alright but the motor just feels and sounds too busy.
My Trailblazer SS just about idles (~1500rpm) at highway speeds. Even my 350Z with 4.08 gears doesn't spin as fast.
Old 01-08-12, 05:59 PM
1siksc
1siksc's Avatar
Update received Ford 8.8 Today
Old 01-08-12, 06:02 PM
Nova
Nova's Avatar
i got excited when i saw ford 8.8 cuz i thought u meant the solid rear axle, oh well. if u need any specs on the ford parts of the axle let me know i work at a dealer and have access to the WSM
Old 01-08-12, 06:45 PM
1siksc
1siksc's Avatar
I hear you, my original idea was ford 9" solid axel until i found out it requres you to rebuild the rear of the car and i was quoted $5,000 for that.
Old 05-13-12, 08:33 PM
INTIMAZY
INTIMAZY's Avatar
Well?
Updates?
Please?
Old 05-15-12, 03:15 PM
1980's Avatar
This is awesome. Please keep us updated.
Old 05-15-12, 03:40 PM
Mer257
Mer257's Avatar
This looks and sounds like a great idea but mk4 tt diff hold 1000hp no problem I know pleanty of guys at the track with a basic diff swap and beat them with no boom yet, to each there own I guess but nice idea
Old 05-15-12, 07:04 PM
kponti
kponti's Avatar
Originally Posted by Ali SC3
I think the idea is good and very innovative, but you are comparing it to an entire 6 speed rear end which is why it seems economical, but you should factor in that most of us just drop lsd's into the existing Differential.
Its already in your SC, can handle lots of power, and there are plenty of ring gear choices that will bolt right up from various I6's and v8's with varying transmissions. you can also get solid diff mounts for it. The lsd costs more, but you could probably buy a few of them for the cost of fabricating a new rear end setup.
here are all the ratios that will swap over to your stock case.
97-00 SC400 3.266
92-97 SC300
6 cyl, AT (4.27 ratio)
6 cyl, MT (4.08 ratio)
98-00 SC300
92-96 SC400
8 cyl (3.92 ratio)
92-96 MKIV Supra
w/o turbo; (4.27 ratio) Limited Slip
w/turbo, AT (3.769 ratio) Limited Slip
97-98 MKIV Supra
w/o turbo; (4.08 ratio) Limited Slip
Sooo can I use any of the limited slip internals listed above in my 2000 SC400? I will like to keep my stock gears
Old 05-16-12, 08:24 PM
Cleet
Cleet's Avatar
My buddy did a 8.8 swap in his rx7 and a strong set of custom axles to hold 1000 HP cost close to $2k. For the lower rated axles he was still quoted somewhere around $1200.
I do like the idea, just don't know if it makes alot of sense in our cars.
Quick Reply: DIY: Ford 8.8" Differential Swap
