W58 shifter bushings 92-94 sc300
![Thumbs up](https://www.clublexus.com/forums/images/icons/icon14.gif)
This is a little more clear how too for the two shifter bushings causing the tranny to shift ruff
tools you need- phillips screw driver, ratchet with 10mm socket, extension, swivel for the socket, flash light
1.![](http://i128.photobucket.com/albums/p184/jtkinkbmx/shifter1.jpg)
2. remove shifter **** (twist counter clockwise)
![](http://i128.photobucket.com/albums/p184/jtkinkbmx/shifter2.jpg)
3.remove shifter boot (pull up plastic frame, there are 4 clips holding it in)
![](http://i128.photobucket.com/albums/p184/jtkinkbmx/shifter3.jpg)
4.open up cup holder and pull out
![](http://i128.photobucket.com/albums/p184/jtkinkbmx/shifter4.jpg)
5. unscrew the 2 screws
![](http://i128.photobucket.com/albums/p184/jtkinkbmx/shifter5.jpg)
6.remove the 6 screws so u can pull back on trim
7.unclip the 2 hazard and volume, a/c switch
![](http://i128.photobucket.com/albums/p184/jtkinkbmx/shifter7.jpg)
8.unclip the cigar lighter
![](http://i128.photobucket.com/albums/p184/jtkinkbmx/shifter8.jpg)
9.unclup the 3 connectors under the radio
![](http://i128.photobucket.com/albums/p184/jtkinkbmx/shifter9.jpg)
10.now under the 4 corners of the boot there are screws the you need to replace
![](http://i128.photobucket.com/albums/p184/jtkinkbmx/shifter6.jpg)
11.lift the boot through the metal bracket you just unscrewed. (this isn't the easiest may take you a little bit)
![](http://i128.photobucket.com/albums/p184/jtkinkbmx/shifter10.jpg)
12.now lift the boot back so u can remove the other 4 screws holding the shifter to the housing (make sure the shifter is in neutral before removing these screws)
![](http://i128.photobucket.com/albums/p184/jtkinkbmx/shifter11.jpg)
13.new pull the shifter out of the housing (that is one of the bushings u have to remove)
![](http://i128.photobucket.com/albums/p184/jtkinkbmx/shifter12.jpg)
![](http://i128.photobucket.com/albums/p184/jtkinkbmx/shifter14.jpg)
this is the green bushing that goes down below the two studs in next picture
![](http://i128.photobucket.com/albums/p184/jtkinkbmx/shifter17.jpg)
14.clean out the inside and try not to let any of the green bushing fell down
15.install the 2 bushings (white to shifter and green to housing. (this is how the bushings will sit when inside the housing)
![](http://i128.photobucket.com/albums/p184/jtkinkbmx/shifter16.jpg)
![](http://i128.photobucket.com/albums/p184/jtkinkbmx/shifter18.jpg)
![](http://i128.photobucket.com/albums/p184/jtkinkbmx/shifter13.jpg)
16. now all you have to do is install the shifter into the housing and reverse the steps. goodluck
1.
+1![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
For a great write up....Just did this with the Marlin Crawler bushing set, and now the shifting is great
....and I just saved myself $100 in labor that my mechanic would have charged me![Woohoo](https://www.clublexus.com/forums/images/smilies/woohoo.gif)
other tools to add to the list: small pry bar(for all the plastic pieces), vaccum, razor blade(mine had the orignal shifter boot covering the last four screws in order to pull the shifter out which i just cut around the screws)
![Woot](https://www.clublexus.com/forums/images/smilies/woot.gif)
Bleak
Performance & Maintenance
32
03-22-13 06:49 PM
1siksc
SC400 / 300 Classifieds
04-28-10 07:29 PM
