I blocked the EGR with a soda can!
Old 01-09-12, 11:37 PM
JZBrian
JZBrian's Avatar
why would you do it like that!? it looks like crap and than you put the valve back on.
Old 01-10-12, 02:54 PM
LEX_MAN
LEX_MAN's Avatar
For doing all that, you could have cut piece of thick metal and drilled 2 holes, but oh well its your car.
Old 01-10-12, 02:57 PM
stockhatch
stockhatch's Avatar
You should have used a diet Dr Pepper can for the weight savings
Old 01-10-12, 07:05 PM
over40driv
over40driv's Avatar
I know this debate has been fought before, something about engine cooling because of reciculating the burned gases. Isnt there also some elec. solenoids involved with the EGR system? If all could be deleted and was a benefit it would be a nice DIY showing all parts removed. Prob. not a good idea in Calif.
Old 01-12-12, 03:55 PM
A32Boost
A32Boost's Avatar
Nice mod its your car, and if you find it to help your car run better im all for it
Old 01-12-12, 06:12 PM
es30000000
es30000000's Avatar
Dude atleast flip it around so its just silver and trim the edges so it's smooth...
Old 01-14-12, 03:11 PM
over40driv
over40driv's Avatar
Ive been reading old threads concerning EGR removal and it looks like there can be a problem with idle quality.
Old 01-14-12, 11:25 PM
mdmaniac
mdmaniac's Avatar
One deletes the EGR mainly to lower air intake temperatures. Seems odd, does it not, to spend money on cooling your intake in order to improve air/fuel ratio only to have the EGR pumping 700° air back into the intake manifold? Of course, the added benefit includes keeping that nasty carbon crap out of the engine. However, bear in mind that EGR works by actually REDUCING the combustion temperatures in the head, which helps to prevent pre-ignition as well as lowing NOx emissions.
The big question: Will deleting the EGR cause the vehicle to fail a state emissions test?
Old 01-15-12, 09:31 AM
WadeLovell
WadeLovell's Avatar
If identified, deleting the EGR will cause the vehicle to fail a CA smog test no matter how fancy or not the block off. I don't think it will pass a visual inspection in this case. At the "Smog Only" and "Gold" smog stations they look pretty closely at the system and I would be surprised if the failure to recirculate the combustion gases wouldn't show up pretty dramatically in the numbers.
Old 01-15-12, 12:15 PM
over40driv
over40driv's Avatar
We dont have emmision testing in my area, so that aside is it worth the effort and the time to clean the engine area up by removing the EGR . If its lowering temps. in the head it dosent seem like it is.
badboylx04
GS - 1st Gen (1993-1997)
04-17-13 09:47 AM
sj408
03-18-10 09:02 PM
turbodremz
12
09-19-09 02:17 AM
Hermosa
17
08-02-03 11:12 PM
Quick Reply: I blocked the EGR with a soda can!
