Problem solved! sourse of power loss, new crank seals and ps hose,espiler springs
Old 01-10-12, 02:41 PM
CAsc300
CAsc300's Avatar
Default Problem solved! sourse of power loss, new crank seals and ps hose,espiler springs
So today i found out the problem to my power loss / poor throttle respnce. i went throught the usial cap and rotor, sparkplugs, wires, maf , vacume hoses. and nothing. so i noticed that my timing was off. after taking it all a part i noticed something odd with the crank shaft gear. The key wore down the metal and gave that gear room to move and constantly change my timing. Is this a usial or common problem? well thought i would point this out as others with power loss problems as i went through a headache of things before i accedently found the sourse. i went ahead and changed my power steering hose. i snaged a like new or redone one from the junkyard for 10$! and while appart i want and orderd cam seal and crankshaft. here are some pics. Oh and update on my car lowerd on espiler springs and kybs.
see where it wore down?
the new one picked up from fresno lexus
olny stock pick of my car i could find
here it is as it sits
i need to get the good camera out
thanks guys
Old 01-13-12, 08:54 PM
Joey-E
Joey-E's Avatar
Congrats... way better lowered
Old 01-15-12, 09:49 AM
WadeLovell
WadeLovell's Avatar
That wear pattern is extremely unusual. The normal problem is being unable to get these bloody gears off the end of the crankshaft. Was the key the correct size?
Old 01-19-12, 07:35 PM
CAsc300
CAsc300's Avatar
well i went around and looked for replacement keys and none of them fit correctly except the one from lexus. so i assume that the key or something was replaced and caused it to wear like that
Old 01-19-12, 07:49 PM
k7q
k7q's Avatar
fishing pole hood prop. awesome!
Old 01-20-12, 07:25 AM
Track5tar
Track5tar's Avatar
glad you got this resolved. i know just how frustrating it can get checking the plugs/coils/MAF ...fuel pump ecu. etc.lol
Old 02-01-12, 11:25 AM
CAsc300
CAsc300's Avatar
yea it was lucky that i found that before going through every little thing.
Old 02-02-12, 03:44 PM
dwebb99
dwebb99's Avatar
sharp eye on that gear issue....god job in finding/fixing.......strangest looking "keyway" on a gear that I have ever seen.....
JonnyO78
11-04-19 05:04 PM
vincity
IS - 1st Gen (2001-2005)
10-04-18 03:08 AM
qpman
08-04-14 06:44 PM
chadster
GX - 1st Gen (2003-2009)
01-07-12 10:47 PM
qhs002
05-13-06 03:12 PM
Quick Reply: Problem solved! sourse of power loss, new crank seals and ps hose,espiler springs
