1jzgte backfiring, wont start
Old 01-16-12, 07:27 AM
Dai Kaiju
Dai Kaiju's Avatar
Default 1jzgte backfiring, wont start
Alright i fixed the iacv past night and then found this problem. I'll turn the key and it cranks and cranks but never turns over until it starts back firing. I'm thinking it's the ECU or Crank Position Sensor but wanted to see if anyone else hand aby ideas
Old 01-16-12, 07:54 AM
TweakTech
TweakTech's Avatar
Check the mechanical timing of the engine. Also, do you have any codes?
Old 01-16-12, 08:39 AM
WadeLovell
WadeLovell's Avatar
What was the issue and code that led you to clean or replace the IACV? As TweakTech said, put a timing light on it. Also, what did you disconnect to do the IACV?
StopOnce
IS - 1st Gen (2001-2005)
11-21-14 11:59 PM
NSeagle78
07-07-11 04:49 PM
LiCelsior
29
03-04-09 10:07 PM
asianrob
Maintenance
02-11-09 09:31 PM
Motoguy187
04-13-05 08:28 AM
Quick Reply: 1jzgte backfiring, wont start
