Soarer clutch master/slave cylinder same as?
Update
installed the rebuild kit for the master and the mk3 slave and it's all good now. So it was the slave cylinder that was the issue...
Little hint for anyone replacing the slave. There is a cover that has two bolts that lets you see where you put the slave... Make sure to take it off and look lol. I installed the slave and i guess missed that ring where it should sit. Did a full bleed with the same problem. Went back under the car and realized there is a cover which lets u see where the slave sit. Without it it would be quite difficult to place it into the correct spot lol.
Its an actual Soarer.
TSleid
Performance & Maintenance
09-11-13 06:35 PM
baodalazi
SC- 1st Gen (1992-2000)
06-20-11 03:21 PM
