Sc400 1jz swap help
Old 01-20-12, 07:01 AM
sc101
sc101's Avatar
Default Sc400 1jz swap help
Iv been reading countless threads about this swap for months now but im still confused about a few things that i want to try and hopefully clear up before i get the engine and tranny this weekend.
  1. one of the main things im hearing is that you need to get a different driveshaft but i also read that for the 1jz auto tranny you can use the stock sc400 shaft? so im just trying to figure out which drive shaft i need to use...i also am going to stick with the auto 1zj tranny
Also do i need to get the sc300 engine fan and housing to do the swap and do i need to get a new radiator as well?
I also read that the wiring is a real pain and i was wondering is the patch harness a short cut for the wiring or is there a way to easily extend the harness?
One of the main questions i have is what are the MAIN parts im going to actually need to complete the swap because each thread i have read each person gets different parts or does a different method of doing the swap?
This is the list i made of parts that i believe i need for the swap please correct me if im wrong i just dont want to start this project and not know what all im going to need to complete it...Im sadly a broke college student
  1. 1JZ-GTE Soarer engine-1JZ-GTE Soarer ECU-Transmission
  2. Intercooler
  3. Supra Upper/lower radiator hoses
  4. Supra TT Accelerator cable(or 92 camery)
  5. Soarer/Supra Igniter- (should come with engine)
  6. New motor mounts
  7. MSD Tach adapter
  8. 330ohm resistor
  9. HKS Fuel cut defencer
  10. Greddy speed limiter cut controller
  11. Supra TT/Walbro fuel pump
  12. 1JZ/2JZ PS Hose-
  13. Oil Pump
Please correct if im wrong i really need help on this parts list
Thanks again for the help
SC101
Old 01-20-12, 07:39 AM
99SC42
99SC42's Avatar
  1. one of the main things im hearing is that you need to get a different driveshaft but i also read that for the 1jz auto tranny you can use the stock sc300 shaft? so im just trying to figure out which drive shaft i need to use...i also am going to stick with the auto 1zj tranny .You needs an SC300 auto complete driveshaft.
Also do i need to get the sc300 engine fan and housing to do the swap and do i need to get a new radiator as well? Just make sure you get a rear sump complete swap with the fan clucth and fan blade, ignitor, map sensor, no broken sensor, no missing sensors, remove the spark plug cover to make sure the coils are not stolen.
Get a whole complete swap make sure again it's from Soarer and it's have a complete harness
  2. Intercooler some time you get lucky
  4. Supra TT Accelerator cable(or 92 camry 4 cylinder cable)
  6. New motor mounts supra TT mount 97-98
  7. Supra TT/Walbro fuel pump
  8. 1JZ/2JZ PS Hose-
  9. Oil Pump
    Tt water pump
    1jzgte Timing belt from driftmotion if you can do the maintenance while the engine is out .Save you alot of time and headache.
    You need an SC300 radiator , supra tt upper and lower lower radiator hose, you can use an Sc 300 lower radiator hose it's the same as the supra.
SC101
Check out everything that is highlighted.
Old 01-20-12, 11:27 AM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
Moved to proper forum
Old 01-20-12, 02:51 PM
sc101
sc101's Avatar
Alright thanks alot for the information im excited to get this build under way
Old 01-23-12, 05:39 PM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
Drive west and come see mine first hand.. Check out my build in my signature.. Its a work in progress..
Old 01-23-12, 05:54 PM
xspsi6
xspsi6's Avatar
I think you need the early supra tt mounts not the late as those are the short bracket with tall mounts and you need the long bracket with short mounts but I am not 100% on that however the info here is cloudy on this subject.
Old 01-23-12, 07:12 PM
99SC42
99SC42's Avatar
The mount subject has been covered over 15000 times a little search and you will find the answer. Don't wanna go off topic on this thread.
Old 01-23-12, 07:48 PM
xspsi6
xspsi6's Avatar
Well if I had 1st hand info I would say for 100% sure however I do not, Sorry as I have seen 6 of one and 1/2 dozen of another when it comes to answers on the mount subject.
Check on supra forums as they are helpful when it comes to this. Sorry I can't be of more help on the subject but this is the direction I have been pointed on the mounts.
sj408
SC- 1st Gen (1992-2000)
02-02-11 11:08 AM
T-Lex
13
10-31-08 08:24 PM
pmpdaddyt
16
01-27-08 01:48 AM
RB26_S13
Florida Lexus Club
06-08-07 09:50 PM
vip_soarer
04-14-07 10:50 PM
Quick Reply: Sc400 1jz swap help
