1UZ partial teardown, pic requests?
Keeper of the light
I have my 1UZ in the air (and waving it like I just don't care) so I thought I'd see if any members have pic requests for certain areas like the crank/oil pump area (the oil pan and shroud is off, crank exposed), or perhaps underside areas like ground bolts, compressor screws, motor mount areas....... anything that you really can't get to normally and can't see.
Also the front of the engine is disassembled so you can see the cam sprocket area, inside the water pump area, timing belt pulleys, etc.
It might not be of use to anyone, but if you are planning on working on your 1UZ soon and need to get some pics of the are you'll be working on that you can't get to or see I'm offering pictures right now of a very well partially tore down engine for anyone that needs to peek inside it.![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
If you have requests, let me know![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
Keeper of the light
Oh hell, Did he just put that entire engine back together, timing belt, distributors, pumps, and all in EXACTLY 2 hours?
Yes he did![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
![](http://i32.photobucket.com/albums/d5/audiogodz1/cfce886e.jpg)
![](http://i32.photobucket.com/albums/d5/audiogodz1/0d680771.jpg)
![](http://i32.photobucket.com/albums/d5/audiogodz1/de595bf6.jpg)
The spark plug covers are just sitting there, gotta get new wires.
BUT I took several pics so I'll put them up in a bit. hopefully it'll help some newb owners.
Yes he did
How bout oil pans, and behind the the motor for rear main seal etc. I just did the water pump and timjng kit while in the car first time 11 hrs. Sucked ***. Then had to get timing right lol..so i hot it down now. Ill b pulling the motor this summer to clean up and new gaskets.
Thanks OLT
Thanks OLT
spo0k
03-19-18 10:45 AM
metaron
RX - 1st Gen (1999-2003)
03-30-13 07:54 AM
nick1126
12-03-11 08:01 PM
jersey1
Performance & Maintenance
11-11-02 11:05 PM
