2JZGTE VVTi swap help please!
Old 04-02-15, 03:49 PM
Monterrey
Monterrey's Avatar
Default 2jzgte vvti problem
Hello it's me again, so if I change the throttle body and the admition the car will run better. I cancelled the dbw and the oem throttle body is move by cable like old school, so I think that the problem is that I don't have the dbw and move the throttle mechanical, the solution is in change the parts that you suggest me?
The will run better with that parts?
Thanks
Old 04-02-15, 09:36 PM
99SC42
99SC42's Avatar
Originally Posted by czar07
Use a non-vvti intake manifold and throttle body
On what ecu?
if you are on the stock vvti gte ecu it will not work ..You need an ems to do that.
First you guys need to jump it at the ecu to get a cel and go from there..otherwise you will be chasing your tail..vvti ecu is very sensitive.
I hate it with passion..ive helped my friend with a aristo vvti swap in the 98 GS300 lol it wasn't that easy.
Old 04-02-15, 10:53 PM
Monterrey
Monterrey's Avatar
Default 2jzgte vvti
Originally Posted by 99SC42
On what ecu?
Hi
Yes I've the oem ECU of the 2jzgte vvti, also I've automatic tranny.
So what I need to do?
You said I need and ems?
What is ems?
Sorry for too many questions but I'm from Mexico and non one have the 2jz, I now I've bad grammar but please give me your advice.
The problem with my swap it is that I feel they are underpermance, when you push the gas pedal to floor I fell that I only use 160hp not 280 I feel my car like the oem ka24de the original engine of my 240sx s14.
Please give all you advices for make a real 2jzgte vvti.
Thanks
Old 04-03-15, 08:20 AM
99SC42
99SC42's Avatar
I will try to help you as much as I can.
First you have to find the F59 connector, ground pin 5 to the chassis , strut tower and you will the check engine light blinking.
Once that happens , we start moving in the right direction.
let me know.
99SC42
99SC42's Avatar
let me know.
Old 04-03-15, 02:42 PM
Monterrey
Monterrey's Avatar
Default Help!!!
let me know.
Ok but Ive and other question, the f59 conector where is it?
You said That I need to find them, but it is in the ECU or where once I will find them what I need to do?
Thanks for be pacient with me but I'm alone on this, becouse nobody have that swap in Mexico.
Thanks and waiting for solutions
Old 04-04-15, 05:22 AM
99SC42
99SC42's Avatar
http://wilbo666.pbworks.com/w/file/f...U%20Pinout.png
5pin is the on that says TC, just T into that wire and ground it.
Old 04-04-15, 07:47 AM
Monterrey
Monterrey's Avatar
Default Help
Ok, I'll do that
So if I can find the f59 connector and do tha wire to the ground my car will run better, it's that possible.
Thanks
Old 04-04-15, 12:00 PM
czar07
czar07's Avatar
On what ecu?
Sorry you are 100% correct 99SC42. For some reason when people say 2jzgte swap, I always assume they are going single + ems haha
Old 04-04-15, 04:55 PM
Monterrey
Monterrey's Avatar
Default Help!!!!!
Please where is the f59 connector? And what I need to do?
Please If I do that my car will run better???
Like a real 2jz gtr VVTI.
Thanks
Old 04-05-15, 12:58 PM
99SC42
99SC42's Avatar
No read my posts , I didn't say it will solve your problem..
I said jump pin 5 from the F59 connector and ground it at the chassis, your check engine light will blink , pull the codes and then we can move forward .
I posted the link so you can see the pictures of your ecu connectors they are all labeled in that link.
Old 04-05-15, 06:54 PM
Monterrey
Monterrey's Avatar
Thanks for the information. Ive read all your post, I'll do that, but I need something to program the ECU or just go to the f59 connector pin 5 and ground to the chassis, or I need to make more thinks.
Here in Mexico I'm alone with this.
Thanks for your pacience and your good communication.
Thanks
VIP161
Performance
01-28-19 06:14 PM
VIP161
24
05-15-13 10:33 AM
shai
04-19-12 02:33 PM
GlobeCLK
Performance
14
02-21-07 05:33 AM
whitelex99
Performance
04-05-06 06:15 PM
Quick Reply: 2JZGTE VVTi swap help please!
