Help with 1JZ Motor
Old 01-24-12, 11:20 PM
yausito
yausito's Avatar
Default Help with 1JZ Motor
Here is the story, I am trying to buy this sc300 in a Online auction. Found out that it come with a 1JZ motor on it. The problem is: The discription of the car said that the car doesn't run.
I am trying to figure out. What is missing under the hood. In order for me to buy the car and be sure in what struggle i am getting into ..
Please let me know what you guys see.
It look like the turbo is missing. or something. But not sure.
Thanks for your help !!
Old 01-25-12, 04:32 AM
spoolxexo
spoolxexo's Avatar
It looks like just the turbo intake pipe is missing, and so is the battery. I don't see the MAP sensor mounted anywhere, you need that to run.
The igniter is mounted on the Driver side strut tower, so that's good.
Don't know why it wouldn't run, wiring? Can't really tell in this picture, more info!
Old 01-25-12, 05:20 AM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
Same things I saw missing. Those are easy to find.
Old 01-25-12, 05:45 AM
StiCk3
StiCk3's Avatar
don't forget the oil cap!
is this on fleabay or something? I would try to get some more info before diving into what could be a potential nightmare
Old 01-25-12, 06:37 PM
yausito
yausito's Avatar
Good eye about the map Sensor.... Not sure if the car run or not. However, It said that ut doesn't run. Anyways, Thanks for your Help ! ...
And Thanks For Other Member here that try to Help me !
Old 01-25-12, 07:49 PM
vangb2
vangb2's Avatar
Cruise control box is missing if you care.
Old 01-25-12, 08:39 PM
yausito
yausito's Avatar
I do care. Hopefully I can win the bid for my desire price and make the car Run . Then I will fiugure out the cruise Box ..
Thanks for the point tho !! ...
Old 01-25-12, 09:11 PM
619Rider
619Rider's Avatar
The battery is the most obvious thing... unless it was relocated to the trunk
chris1jz
16
11-09-12 12:37 AM
PoGikoSc4
Southeast
02-08-11 01:57 AM
drewdizzle
CL of Southern California
12-28-10 10:53 AM
Bcasey
SC- 1st Gen (1992-2000)
14
08-19-10 09:24 PM
Quick Reply: Help with 1JZ Motor
