I bet no one here can tell me what shifter this is on a r154!
so i just got a r154 but it has this retainer(housing). anyone seen it before? i may try getting the shifter that matches it. worst case senerio i cut it off and just bolt the original back. or see if someone will sell the one they didn need.
car was lost to state and they auctioned the car then the guy didnt know how to get it to run with the jdm motor so he parted it and it didnt have a shifter. i have heard short throw and short shifter and ford shifter and chevy shifter and even volkswagen? i do not have any clue. again ill be happy to replace it with the stock supra retainer. i made a shifter to fit the sc300 and use the mk3 housing.
i have used the supra retainer. i just modified a shifter i had in garage to accept the sc platform. any ideas on where i can get a supra retainer cheap? id rather not spend money on a new setup
any ideas on finding a cheap supra retainer?
i have yet to be able to use classified's due to cl 30 day 30 post requirement.
I would get the Soarer parts like Biggu said. That way the thing will fit in your car without issues and the shifter movement and position won't be compromised. I bought mine from Champion Toyota.
These should be the part numbers you need.
Housing, Shifter (33521-24040)
Control Shift Lever (33570-24010)
i just want a cheap mk3 retainer(housing) i talked to mike at champion and those parts are to expensive. i have a custom shifter that will work with supra housing and fit sc.
I guess no one knows what shifter is welded to this r154?
looks like i will cut it off and mill it and attempt to put pins into the housing too. i guess the guy b4 knocked them out.
