Rebuild my 2J or put in a 1J?
in reality the 2jz's are built equal in my eyes other than the minor differences in bolt pattern, interchangeability, compression, etc. when you want a reliable motor you really want to look at a good maintenance, the correct mods to match each setup and a "GOOD TUNE". i will change my mind in which one is stronger once someone does a tensil strength test/ stretch test on ge and gte rods/ pistons/bolts/etc. other than what ive said i have seen high power numbers in both motors and also failures in both. to the op i would just buy a used ge and work with it since theyre so cheap and plentiful. i dont ever see myself downgrading from a 3.0 to a 2.5 even though the 1j is faster but thats comparing apples and oranges since one is NA and the other is FI. on the same playing field both being boosted i think 2j would dominate in power and cost
But other then that I'm totally with what he said....
I have the same kinda mind set as you man.. IF i were in your shoes/situation and had the funds, I would upgrade whats broken, get it honed and new rings, maybe some crank rods for the rebuild, then turbo it (with a ffim and standalone if $ permit).
And like others said, I'd baby it til u get a beefier tranny if needed for power numbers desired. save money for tranny and lsd
But i would not go to a 1jz swap cause you run the risk of the same thing happening again, a bearing go bad or worse. This one you got a reason to start fresh
