HELP SC400 wont start
Hi have just bought an SC400.
ok it has been sitting around for around a year, when it went to lexus for timing belt change.
then sat around for few months...when started was found power steer pump was leaking.
sat for few more months...workshop started it and was running for 10 mins then stopped.
no longer starts...have had ECU sent away and was bench tested all ok.
car pulses injectors once fuel pump pulses once and 1 spark every time trying to start.
any ideas please
any ideas please
thought this was a forum.....exchanging ideas...and past experinces to problems and fixes? ?
so please explain why this the wong place?????
or did you just feel like posting a reply ....to see your name in print?
I think this is the correct section.
So does it crank? If so spray some starting fluid in the throttle plate and try starting it. If it starts and dies its probably fuel related. If it doesn't start then its a spark issue. Good luck
Thank You, yes it cranks.....
when being cranked....send one spark from coil thats it
and quick signal to pump .....
pulses injectors once.....
thats it..
thats it..
