crank pulley off, balancer still on..what next?
i finally got this bolt loose tonight and now its dark so i can see in there very well but the pulley came off and the balancer portion is still in there...how do i pull this off? wont be able to fiddle with it until tomorrow and tried searching but i havent found anything that pertains to exactly this..so any help would be appreciated..im sure its something easy but like said its dark and i would just like a definitive answer before i get home tomorrow since my time is very limited as of lately and i need this running!!
hey, I think I have the same problem. My harmonic balancer separated from the rubber inner ring thingy and totally flew out off of the shaft, gouged the fan, and ended up sliding around in the underbelly of the car! Luckily not much harm done, as the fan still works with the gash in it, and the belt somehow stayed on and works just fine. I found a replacement part for the harmonic balancer, but my local shop says that there is a special tool to get the thing off - they tried for 4 hours to no avail! Am trying to avoid a costly labor charge from the dealership so I want to verify whether this does in fact require a special tool to remove, or what?? Thanks!
Dedik8d1
SC- 1st Gen (1992-2000)
09-02-11 09:12 PM
