sc400: intake manifold porting and gasket matching
Old 02-18-12 | 06:49 AM
dawhorl21's Avatar
dawhorl21
Default sc400: intake manifold porting and gasket matching
so i finally decided to try and port and polish my intake manifold.
Attached Thumbnails sc400: intake manifold porting and gasket matching-20120218_003349.jpg   sc400: intake manifold porting and gasket matching-20120218_003443.jpg   sc400: intake manifold porting and gasket matching-20120218_021119.jpg   sc400: intake manifold porting and gasket matching-20120218_023247.jpg
Old 02-18-12 | 09:22 AM
SChema's Avatar
SChema
Very nice, it's amazing sometimes how much intake manifold flange - head ports and head ports - exhaust manifold flange are so off. A friend had a head done by Headgames and the difference is quite astonishing, there's so much left on the table from factory.
Old 02-18-12 | 11:29 AM
xspsi6's Avatar
xspsi6
I see the port part but where is the polish? Lol
Old 02-18-12 | 12:31 PM
dawhorl21's Avatar
dawhorl21
Its no were near done I was just showing how much can be taken off. I still have to sand and polish but ill keep the pictures coming
Old 02-18-12 | 04:16 PM
DJVe's Avatar
DJVe
just curious, but what year sc4 is this off of? also was the porting done somewhat randomly/intuitively, or were you able to do any flow testing before/after?
lastly while good porting leads to good things, i have read a few times that polishing sometimes can have negative effects on the air flow, and if not negative, then no effect. i dont know how much this is true or if it is applicable to certain designs/materials, but perhaps you could shed some light on it if you know?
Old 02-18-12 | 05:33 PM
xspsi6's Avatar
xspsi6
He did a gasket match which is not messing with cyl head ports where shape ,flow and velocity comes in to play so not very critical as you are not re shaping the port where the power is made.
To pay for flow bench testing would be silly as there is very little to be gained although it by no means can hurt as the 1uzfe is full of restriction but the heads,plenum and cams work very well in a stock only set up as Toyota did a good job and made one of the most reliable engines ever to hit production.
Also polishing is not needed and will impede atomization as 80 grit rolls leave the desired finish for mixing the air/fuel in the most efficient manner.
Old 02-18-12 | 05:43 PM
SChema's Avatar
SChema
Correct, port and polish is porting the intake side leaving a somewhat rough finish for fuel atomization as xspsi6 said. Polishing is typically on the exhaust side, leaving a clean surface so carbon cannot build up on the walls.
Old 02-18-12 | 10:39 PM
dawhorl21's Avatar
dawhorl21
No sry It was spur of the moment so I didnt plan on any flow testing. And I am gasket matching plus a little bit of porting. The ports seemed small and restrictive so I widened them. I did both the top and the bottom manifold. I had read somewhere the porting and gasket matching gained an ls1 something like 35hp so I am hoping for something decent. I am gonna try and dyno test it after this is over.
Old 02-19-12 | 05:10 AM
DJVe's Avatar
DJVe
nice! looking forward to see your results.
Old 02-19-12 | 06:08 AM
dawhorl21's Avatar
dawhorl21
Default upper manifold finished
finished the upper manifold and starting on the lower
Attached Thumbnails sc400: intake manifold porting and gasket matching-20120219_042424.jpg   sc400: intake manifold porting and gasket matching-20120219_042438.jpg
Old 02-19-12 | 06:11 AM
dawhorl21's Avatar
dawhorl21
Default lower manifold
the lower manifold
Attached Thumbnails sc400: intake manifold porting and gasket matching-20120219_031133.jpg   sc400: intake manifold porting and gasket matching-20120219_035338.jpg
Old 02-20-12 | 09:56 AM
Boergy's Avatar
Boergy
wow! thanks for the pictures! i hope, you give a response, after install and the first drive
Old 02-20-12 | 07:13 PM
dawhorl21's Avatar
dawhorl21
there is alot you can take off the bottom manifold. its ports are alot smaller then the gasket
Attached Thumbnails sc400: intake manifold porting and gasket matching-20120219_182801.jpg   sc400: intake manifold porting and gasket matching-20120219_182742.jpg   sc400: intake manifold porting and gasket matching-20120219_182719.jpg
Old 02-20-12 | 07:16 PM
dawhorl21's Avatar
dawhorl21
and finally last putting everything back together which is a pain lol
Attached Thumbnails sc400: intake manifold porting and gasket matching-20120219_231851.jpg   sc400: intake manifold porting and gasket matching-20120219_234727.jpg
Old 02-20-12 | 07:21 PM
dawhorl21's Avatar
dawhorl21
when i drove it i really didnt know what to expect but after three days of grinding and sanding i have to say its worth it. i really cant say how much horsepower i get until i dyno it but it takes less to go fast is the easiest way of putting it lol. i feel like i gained alot of torque and midrange. i havent been on the freeway so i cant tell you about top end. the transmission seems like its not used to the engine revving that fast plus its alot smoother acceleration and im on bad oil and need to flush my tranny so i am kinda excited once it sees that new mobile one. i'll put a video on youtube and paste a link
