E-Brake Light On
Old 02-23-12, 07:57 PM
Factory5
Factory5's Avatar
Default E-Brake Light On
I have a 92 soarer and from what i remember when i bought the car the brake light was off but i really don't remember but what i do know is that its on and that it wont go off.
This is what Ive checked:
all taillight bulbs replaced
all headlight and signal bulbs replaces
brake pads all new
fluid in the clutch reservoir
fluid in the brake master cylinder
Ive even cut the purple wire on the brake failure lamp module to see if there was a problem there but its still on. So if you've had a similar problem and fixed it help would be greatly appreciated thanks.
Old 02-23-12, 08:11 PM
poorsupra
poorsupra's Avatar
mine comes on and stays on every once in a while, i think its grounding out on my seat somehow, only happens on hard braking and goes away during acceleration.
Old 02-23-12, 08:14 PM
Factory5
Factory5's Avatar
Thanks for the quick reply but no it has never turned off
Old 02-23-12, 09:20 PM
Kalogerus
Kalogerus's Avatar
You might wanna flush your brakes and check for leakage.
Old 02-24-12, 05:10 AM
bodydrager
bodydrager's Avatar
Check the ground on the emergency brake. I've had a few cars with the same issue and it was just a loose connection or the terminal was pulled off somehow.
Old 02-24-12, 01:11 PM
FAT HEAD
FAT HEAD's Avatar
weird.... my light always comes on when i'm low on brake fluid and goes away when i put more in it.
Old 02-24-12, 05:51 PM
Factory5
Factory5's Avatar
i wiggled the only cable that i could see around the ebrake and still nothing do you know of a diagram online so that i could see what im looking for?
Old 02-24-12, 05:52 PM
Factory5
Factory5's Avatar
ya thats the first thing i checked and it was still on
Old 02-24-12, 09:19 PM
Warrenlex
Warrenlex's Avatar
Mine does the same. Sounds like a wiring issue. I saw a wiring manual for 300's on amazon, I may give that a shot.
Old 02-25-12, 11:24 AM
cameratoaa
cameratoaa's Avatar
Check your brake fluid it is probably low. You may have a leak.
Old 02-25-12, 11:28 AM
Factory5
Factory5's Avatar
There is fluid and ive never needed to top it up
Old 02-25-12, 11:02 PM
sweetchuck
sweetchuck's Avatar
check the e brake itself . mine was on and when i put it back together, the spreader was not connected and was just hanging it (light) went off.
Old 02-26-12, 12:29 AM
Factory5
Factory5's Avatar
whats the spreader?
Old 05-20-12, 11:09 AM
Factory5
Factory5's Avatar
found the problem the wires from the master cylinder were cut by some idiot
jcollis217
12
09-30-13 07:48 PM
rjtillman
GS - 1st Gen (1993-1997)
11-06-12 09:59 PM
BOPOH
SC- 1st Gen (1992-2000)
13
06-27-11 06:15 PM
cqcas59
RX - 1st Gen (1999-2003)
16
01-21-10 08:01 PM
CoreY2K1
Maintenance
11-03-02 12:59 AM
Quick Reply: E-Brake Light On
