supra harness, with a aristo motor
Old 02-24-12, 09:54 AM
pourSc
pourSc's Avatar
Default supra harness, with a aristo motor
Has anyone ever used the aristo motor with a usdm supra harness? If so, is there anything that needs to make it work? Is it the same as the aristo wiring process with extending it...I thought I read somewhere that body harness for usdm supra is the same as the sc300 body harness. Please help guys!
Old 02-24-12, 10:31 AM
88supramki
88supramki's Avatar
supra and sc harnesses are definitely not the same
Old 02-24-12, 10:44 AM
pourSc
pourSc's Avatar
are the body pins the same? I can buy a supra tt harness to go with my aristo motor. I am not sure if the body pins are the same
Old 02-24-12, 11:47 AM
99SC42
99SC42's Avatar
Just buy the harness from tweak and be done with it, if you can't make your own. The body plugs are completely different. Don't buy a supra harness if you gonna put the engine in an SC just get a cheap aristo harness and you SC harness send both to tweak and let him make you a harness it's cheaper that way.
Body pins are different
Old 02-24-12, 12:23 PM
pourSc
pourSc's Avatar
Thank you for the info..
Old 02-24-12, 01:16 PM
99SC42
99SC42's Avatar
If you find a Mk4 supra TT harness it will cost you atleast 700 +$$ for tweak to make it PNP for SC, where you can get an aristo harness for for 150 -200 and then send that to Tweak with your SC harness + whatever he charges and come out cheaper that way.
Old 02-25-12, 07:23 AM
pourSc
pourSc's Avatar
i took your advice. Got another aristo last night. Thanks guys
Old 02-25-12, 04:55 PM
99SC42
99SC42's Avatar
Yes send that to Dr tweak with your SC harness and that will come out cheaper instead of going with Supra it's already too expensive and it will not work w/o modification on the SC.
rpk2012
SC- 1st Gen (1992-2000)
12-02-10 08:52 PM
LCSC
SC400 / 300 Classifieds
06-02-08 07:23 PM
na4now
09-02-07 04:07 AM
WICKED 1
08-14-07 05:45 PM
Quick Reply: supra harness, with a aristo motor
