flywheel question
Old 02-24-12, 10:45 AM
SC300_704
SC300_704's Avatar
Default flywheel question
it's been awhile since i last took off my flywheel but i just recieved my lightweight flywheel today and the hole in the center is a lot bigger than the pilot bearing. is that normal, i always thought the pilot bearing was supposed to be a snug fit in the center hole? i need to know if it's right or wrong so i can send it back.
Old 02-24-12, 02:49 PM
StiCk3
StiCk3's Avatar
pilot doesn't sit in the flywheel, it's supposed to sit in the crankshaft you'll see it when you get your trans pulled.
Old 02-24-12, 08:13 PM
SC300_704
SC300_704's Avatar
Thanks, I kind of had a feeling it was supposed to go there.
Old 02-24-12, 10:02 PM
SC300_704
SC300_704's Avatar
btw do anyone remember how many quarts does the w58 takes?
Old 02-25-12, 08:16 AM
stockhatch
stockhatch's Avatar
Its like 2-3/4. Just pull the fill plug, and pour it in the shifter hole until starts to run out of the fill plug hole.
Old 02-25-12, 08:55 AM
SC300_704
SC300_704's Avatar
thanks. i did it a few times before but it's been 2+ years ago and i just forgot how much quarts it uses.
Kobrakai
01-09-16 10:06 PM
megamax
SC- 1st Gen (1992-2000)
14
07-08-11 03:44 PM
1995Lexusc
03-16-10 11:01 PM
trufanatic
07-22-09 07:07 PM
Quick Reply: flywheel question
