Best Synthetic Oil for 1JZ/2JZ ?
#31
1JZ Single SC400
This is why i love this forum. This is alot of great info on oil breakdown and wear. I will continue to change around 5k or so with a Wix filter. Only time will tell on the oil color and breakdown.
#33
Thats pretty often man, maybe every other week or something. I switch around to different oils, been using alot of Mobil 1 synthetic, but I always always use a Purolator Pure One Oil Filter. they have really good filtration and the grip on the outside is great for those of us who still believe a oil filter should be hand tightened and removed by hand. If you cannot break it free by hand, its too tight.
#34
I dont know; ive always been a customer of mobile 1 fully synthetic in all my past cars but upon the second oil change ( i had some spare 10w30 left over which ive used on the first change) i've heard what sounded to be valve tick.
normally id prep an open weekend for valve adjustment but apparently im not the only person who has been experiencing similar (louder valvetrains) with mobile 1. not sure what to use next but im definitely steering clear of royal purple with other peoples bad experiences.
what are your suggestions besides the german castrol which i plan to try?
btw you guys are set on using a 0-30? im in arizona so tempts range from 60 on a cold day to 100
#35
the car normally calls for 5w30, if you are experiencing any ticking on start up you should go back to 5w30 from 10w30. if you get the ticking still after the car is fully warm, then its not the first number on the oil. I would only use 10w30 in the summer, if even at all, and change it out before winter hits. Your climate would be good for just running 5w30 year round to be honest.
#37
#39
Both oils will have the same thickness of 10 cS at 212 F (most engine's normal operating temperature). So yes, in Arizona, you will be fine using 0W-30.
If you want to try something else besides GC, you could try Amsoil, or Redline. Redline is the most expensive at around $10.50 a quart, but it's about the best oil that you can buy off the shelves (or online).
If you experience increased noise with a thinner oil, this doesn't mean use an oil that's too thick. It means repair your engine.
On Mobil 1: they used to sell high quality Group IV synthetics, but they have sadly gone the route of hydro-cracked Group III's while charging ridiculous prices. I am not a fan of Mobil 1.
FusionMan79
332
02-01-21 02:01 AM
