I am in the middle of an aristo 2jz-gte swap in my sc300 and had a quick question about the motor mount brackets. Can I re-use the motor mount brackets that are already on the aristo block and simply change out to sc300 or 97-98 TT supra mounts or do I have to change out the motor mount brackets too from my SC300 motor?
thank you for your quick reply. Ok will do. I noticed that one bolt from the engine mount bracket won't come out because the oil filter bracket is in the way. do I have to remove or loosen it to get out the engine mount bracket ?
