sc300 1jzgte jzx90 swap tach fix and speedo fix ?
whats up guys i have a jxz90 1jzgte motor in my personal car 92 sc300 ... motor runs great and everything works **** BUT...... the speedo and tach dont work how do i do this i have already done the cluster bypass and no go ... if someone has a answer please be specific of what wire to what sensor to what plug .....
i did download the fsm and i printed out the sc300 cluster diagram it helped out a bunch and i still am having problems... i found the wire that runs to the IK1 plug its black it did the resistor 109 bypass and still have noting the gauge doesn't Even move.. as far as speed goes the 2 wire sensor is the speed sensor off the ecu pink and purple wires .. then the acc i believe idk what to do do i connect the wires from the speed sensor to the IK plug direct and then run signal from the ecu to the cluster .... and back to tach .. i supplied signal from the IGF of the 1jzgte ecu and still dont know ...
bump.... still have no tach and temp ordered tach adapter and already jumped resisor 109 have no idea wtf im doing about speedo .. need help... someone have pics
acidreian
Performance & Maintenance
01-15-14 05:32 AM
