Pics of your oil feed/return setup thread!!
its actually mounted directly to the block now like this but
you can check out my oil lines in my thread here, https://www.clublexus.com/forums/per...-thread-7.html
the oil filter adaper is by derale part number 15703
http://www.jegs.com/i/Derale/259/15703/10002/-1
the oil filer mount is by earls, billet temp a cure filer mount 2178
http://www.jegs.com/i/Earl%26%23039%.../2178/10002/-1
I show jegs because they are down the street from me and that's where i got it. I am not using a thermostat of the oil also becuase my car is pretty much track only and I get enough time to let the oil warm up however derale makes one for $40 some bucks that should work
http://www.jegs.com/i/Derale/259/25719/10002/-1
soarer130y, IIRC its 3 or 4 foot but I cant remember at the moment.
I'll tell you one thing. The diesel guys talking about -10 AN lines possibly being too small for an oil drain isn't far fetched.
Check out youtube and search for turbo oil drain videos. There's a couple videos where the people actually let the oil flow into a bucket or bottle, while the car is running and it's amazing how much oil actually flows out of the drain. It's not a small trickle, it's ALOT and when you rev the motor, it's even more!
This is actually a really cool looking oil drain.
http://sourceautomotive.biz/flexibleturbooildrain.aspx
Forum Administrator
![](https://www.clublexus.com/forums/images/ranks/rank-admin2.gif)
Problem with adding that discrete a sub forum is that it gets a LOT less views (fewer answers, less education for other members that want to learn, etc). What we can do is create a more discrete section of the FAQ / DIY sticky for the best threads you want to nominate to go in there. Maybe even do a second mirrored one specific for FI in the performance section
