1jz guys what clutch fan and shroud are you using?
Old 03-12-12, 09:06 AM
xspsi6
xspsi6's Avatar
Default 1jz guys what clutch fan and shroud are you using?
There seems to be lots of combos people tend to run such as sc300 fan and shroud,supra tt fan and shroud,modded ls400 fan w/sc000 shroud etc etc so I would like to get a general idea of what folks here are running.
Thanks in advance
Old 03-12-12, 10:10 AM
Justin727
Justin727's Avatar
I'm running a TT supra radiator with shroud and supra fan. I need to get a supra fan clutch because the one that is currently on my SC will cause the fan to make contact with the water neck/coolant pipe. I had to make customer spacers so it wouldn't take out my new fan as it did the old fan.
Old 03-12-12, 05:30 PM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
I am using the SC300 fan shroud and radiator, but the stock 1jz fan. I chose this for the stock unit look as much as possible.
Old 03-12-12, 05:50 PM
StiCk3
StiCk3's Avatar
im using all my old engine's cooling components (fan, fan clutch, rad. and shroud). Hopefully later this year i'll drop in a Supra radiator as my old one is starting to change colors....
Old 03-12-12, 06:19 PM
xspsi6
xspsi6's Avatar
Ok this confirms what my intial thought so I will just go with stock SC300 stuff, My car is a 400 so I had to figure an exact plan of attack.
Thanks for your input guys!
Old 05-03-13, 08:40 PM
whomiked
whomiked's Avatar
I have a 1jzgte sc300 with an aftermarket Mk4 radiator. What clutchfan/shoud can I use, MK4 for both???
1jztts
05-10-13 08:18 AM
JohnnyB822
09-08-10 12:18 PM
MikeNguyen
North Texas Lexus Club
01-12-10 07:29 PM
1JZ300
SC400 / 300 Classifieds
12-29-06 09:36 AM
Quick Reply: 1jz guys what clutch fan and shroud are you using?
