How do I get 1jz to run low imp top feed 440 injectors?
Ok so I have a top feed rail conversion and 6 440cc DSM low impedance injectors so I assume I need a resistor pack from a mkiv but is there any other resistor packs that will work?
The stock 1j injectors are 370cc and high impedance correct?
You can run a Honda resistor pack for a V6, or 2 4cyl Honda resistor packs. A USDM 2JZGTE resistor pack is the easiest though. Driftmotion sells them at a very reasonable price.
I sent you a PM....yea just insert a Res box, you will need the plug with the wires going to the injectors. Easy to wire up. Inserted it to my Sc300 harness at first and then bought TT harness.
Why not just pick up some aristo 440s for less than $100? Then just drop them in and you wont have to mess with the rail, resistor pack, or injector plugs? :/ Seems like you are doing a lot of modding for very little gain.
what you talkin bout foo? where would one go about finding them for so cheap?
Yes the side feeds can be had for under 100.00 but I already have a top feed rail and all of the plumbing and the 440's are just a steping stone untill I wire in the standalone and 780's
Do you really need to bump a 2 year old thread to ask for a video on how to go about adding a resistor to the injector power circuit?
I love seeing comments like this that discourage asking questions on old threads yet, everyone gets butt hurt if someone doesn't search before asking on a new thread. C'mon man, be fair..
Dude. Your comment has no legs. Maybe if this hasn't been covered EVERYWHERE online that people speak JZ, but it has. There is no need for a video. I found this information on the Internet 5 years ago, from multiple sources. Now, 5 years later, theres like triple the sources. some people just wanna be lazy and have people spoon feed them.
Google search 95 supra tsrm and look in the engine control section. Or better yet, read the section that teaches you how to use the manual first, then move onto engine control
